Handle 10 bytes data
Good afternoon,
Can you think of a way to give the client a text field (or 6 different fields since the password is 6 digits) to fill in those 10bytes?
This Blumotix device (see attached manufacturer's information for the 10byte object) works with 6 digit keys in 10byte format, the last byte determines whether you write or delete the key.
The idea is to set up a visualisation so that the client can write the key every time he wants to change it and with a button we can write correctly on the device.
Thank you in advance for your help,
Greetings !
Handle 10 bytes data - by Kilogica - 24.02.2021, 10:38
RE: Handle 10 bytes data - by admin - 24.02.2021, 10:42
RE: Handle 10 bytes data - by CristianAgata - 14.08.2021, 15:41
RE: Handle 10 bytes data - by Kilogica - 24.02.2021, 10:53
RE: Handle 10 bytes data - by Alberto.ricof - 02.02.2022, 18:25
RE: Handle 10 bytes data - by admin - 03.02.2022, 06:48
RE: Handle 10 bytes data - by Alberto.ricof - 03.02.2022, 23:17
