03.02.2022, 07:20
The current BACnet client implementation is rather limited as everything has to be done via scripts and only a single script can handle all communication. If only reading BACnet devices is required then it can be done. If both reading and writing is needed I would not recommend more than 50-100 objects in total. There's also an app but it uses the same approach so the same limitations apply.
If LM is a BACnet server then it can handle 1500 objects.
