Solcast API
Hi @all,
I need your help please. I want to use the solcast API to get a forecast for my photovoltaic system. In detail I want to get the hourly forecasts for the next 24 hours and write them to group addresses.
Here is the link for the API documentation: https://docs.solcast.com.au/?_ga=2.24121...i-pv-power
Here is my actual code:
require('json') https = require 'ssl.https' appid = 'XX' lat = '52.436225' lon ='10.42526' azi = '170' hours = '24' format = 'json' tilt = '33' capa = '8' ​ url = 'https://api.solcast.com.au/world_pv_power/forecasts?latitude=%s&longitude=%s&hours=%s&format=%s&tilt=%s&capacity=%s&azimuth=%s&api_key=%s' url = string.format(url, lat, lon, hours, format, tilt, capa, azi, appid) ​ res, code, headers, status = ssl.https.request(url) log (code, status, headers) data = json.pdecode(res) ​ --Fault messages: if not data then   alert('Error converting data')   return end if not res then   alert('Error collecting data')   return end data = data.forecasts -- forecast +30min grp.write('45/1/1', data.pv_estimate) ​
I getting the following failure message:
Solcast 08.02.2022 22:01:35 User script:36: attempt to index field 'pv_estimate' (a nil value) stack traceback: User script:36: in main chunk
Where is my failure? Can you help me please?
Many thanks for help!
Best Regards
Steffen
Solcast API - by pioneersteffen - 08.02.2022, 21:21
RE: Solcast API - by admin - 09.02.2022, 07:44
RE: Solcast API - by pioneersteffen - 09.02.2022, 21:11
RE: Solcast API - by admin - 10.02.2022, 08:28
RE: Solcast API - by pioneersteffen - 11.02.2022, 08:18
RE: Solcast API - by admin - 11.02.2022, 08:34
RE: Solcast API - by pioneersteffen - 06.03.2022, 12:13
