(16.02.2022, 07:12)admin Wrote: Event script that gets the target level and adjusts the output object in small steps. Adjust as needed:
Code:output = '1/1/4' step = 5 delay = 0.5 target = event.getvalue() current = grp.getvalue(output) if target == current then return end while true do if current < target then current = math.min(current + step, target) else current = math.max(current - step, target) end grp.write(output, current) -- stop when target is reached if current == target then return end os.sleep(delay) -- stop when targed changed, another script is running if grp.getvalue(event.dst) ~= target then return end end
Thanks! Works perfectly! Would recommend to note this somewhere as a standard script for EC fancontrol (0-10V controlled fans)
