Scheduled Script - Feb 31st
Sometimes I create scripts that should never be run automatically. This is usually for testing or convenience. I usually make these as scheduled scripts, so I can press "Run script" to execute the code.
As a scheduled script normally should be run automatically, you still need to fill in the cron format as to when the script should execute. Usually I just fill inn "* * 31 2 1", so that it should never execute automatically. This is February 31st, which will never occur.
I did however notice that the script is being executed automatically today. Is this expected behavior or is this a bug in your cronjob handling?
See the attached images. For now, I'll just have to disable the scripts, which is fine.
Edit: This bug occurred in another site I have such a script enabled. That was a lightshow script for floodlights at a football stadium. Every Monday the customer complained that the lights turned on a midnight and stayed on. I didn't connect this until now. So it seems the bug is that the script runs every Monday of February.
It might be in the spec of cronjobs, that when it runs into an invalid date, it runs on every occasion instead.
Scheduled Script - Feb 31st - by avolle - 21.02.2022, 15:59
RE: Scheduled Script - Feb 31st - by admin - 21.02.2022, 16:36
RE: Scheduled Script - Feb 31st - by avolle - 21.02.2022, 17:10
