Modbus profiles examples
#52
(23.03.2022, 14:41)admin Wrote: Size is always 1 register (16 bits) no matter what the data type is. The system will read the required number of registers based on the data type chosen.
Block read is needed for certain devices that don't allow reading registers directly but only via a large block read. Block read can be useful in large projects since it speeds things up but usually values can be simply read one by one.
See this example on how it should be specified correctly: https://forum.logicmachine.net/showthrea...4#pid21834
Ok, thanks for your answer!!
Modbus profiles examples - by AEK - 15.06.2017, 07:43
RE: Modbus profiles examples - by morak - 15.06.2017, 10:59
Modbus profiles examples - by ELO - 17.10.2017, 05:29
RE: Modbus profiles examples - by admin - 21.10.2017, 06:05
RE: Modbus profiles examples - by Gadjoken - 23.10.2017, 08:53
RE: Modbus profiles examples - by thientiti01 - 24.11.2017, 07:52
RE: Modbus profiles examples - by AEK - 27.11.2017, 09:18
RE: Modbus profiles examples - by thientiti01 - 27.11.2017, 10:25
RE: Modbus profiles examples - by jetsetter - 30.11.2017, 12:22
RE: Modbus profiles examples - by admin - 30.11.2017, 12:36
RE: Modbus profiles examples - by m.j.sorokin - 30.11.2017, 17:29
RE: Modbus profiles examples - by jmir - 04.12.2017, 14:19
RE: Modbus profiles examples - by FatMax - 05.12.2017, 22:53
RE: Modbus profiles examples - by admin - 06.12.2017, 07:01
RE: Modbus profiles examples - by FatMax - 08.12.2017, 09:06
RE: Modbus profiles examples - by Kaveckiy - 13.09.2018, 06:24
RE: Modbus profiles examples - by fiLLLip - 03.01.2019, 05:52
RE: Modbus profiles examples - by Daniel - 08.03.2019, 11:35
RE: Modbus profiles examples - by AlexLV - 10.03.2019, 15:12
RE: Modbus profiles examples - by admin - 11.03.2019, 07:35
RE: Modbus profiles examples - by AlexLV - 11.03.2019, 11:47
RE: Modbus profiles examples - by Rick - 19.10.2020, 09:53
RE: Modbus profiles examples - by Daniel - 19.10.2020, 09:59
RE: Modbus profiles examples - by Rick - 19.10.2020, 10:16
RE: Modbus profiles examples - by stavros - 29.10.2020, 14:13
RE: Modbus profiles examples - by admin - 29.10.2020, 14:25
RE: Modbus profiles examples - by stavros - 30.10.2020, 10:38
RE: Modbus profiles examples - by stemic01 - 04.11.2020, 20:56
RE: Modbus profiles examples - by AnLi_HOUSE - 11.11.2020, 18:33
RE: Modbus profiles examples - by victor.back - 20.11.2020, 18:34
RE: Modbus profiles examples - by epps - 18.07.2021, 15:05
RE: Modbus profiles examples - by epps - 18.07.2021, 18:21
RE: Modbus profiles examples - by lasttrip - 06.08.2021, 06:14
RE: Modbus profiles examples - by admin - 06.08.2021, 08:14
RE: Modbus profiles examples - by edgars - 26.08.2021, 08:22
RE: Modbus profiles examples - by Daniel - 18.10.2021, 13:47
RE: Modbus profiles examples - by tthamm - 08.01.2022, 07:31
RE: Modbus profiles examples - by admin - 10.01.2022, 08:07
RE: Modbus profiles examples - by tthamm - 23.01.2022, 17:27
RE: Modbus profiles examples - by admin - 24.01.2022, 07:14
RE: Modbus profiles examples - by tthamm - 02.10.2022, 10:48
RE: Modbus profiles examples - by Dré - 04.10.2022, 15:09
RE: Modbus profiles examples - by gtsamis - 28.01.2022, 18:05
RE: Modbus profiles examples - by Daniel - 31.01.2022, 08:41
RE: Modbus profiles examples - by gtsamis - 31.01.2022, 08:48
RE: Modbus profiles examples - by Ian@GWTi - 21.03.2022, 11:10
RE: Modbus profiles examples - by jmir - 23.03.2022, 13:43
RE: Modbus profiles examples - by admin - 23.03.2022, 14:41
RE: Modbus profiles examples - by jmir - 23.03.2022, 15:05
RE: Modbus profiles examples - by khalil - 15.06.2022, 14:11
RE: Modbus profiles examples - by Daniel - 15.06.2022, 14:42
RE: Modbus profiles examples - by admin - 16.06.2022, 07:12
RE: Modbus profiles examples - by khalil - 16.06.2022, 13:59
RE: Modbus profiles examples - by Ian@GWTi - 22.07.2022, 14:27
RE: Modbus profiles examples - by admin - 26.07.2022, 06:23
RE: Modbus profiles examples - by Daniel - 03.10.2022, 07:54
RE: Modbus profiles examples - by tthamm - 03.10.2022, 18:04
RE: Modbus profiles examples - by Daniel - 04.10.2022, 07:39
Modbus profiles examples - by fabiorusco - 27.12.2022, 14:48
RE: Modbus profiles examples - by fabiorusco - 28.12.2022, 07:01
RE: Modbus profiles examples - by admin - 28.12.2022, 07:30
RE: Modbus profiles examples - by fabiorusco - 28.12.2022, 08:32
RE: Modbus profiles examples - by pritorianz - 10.03.2023, 10:12
RE: Modbus profiles examples - by provodkapro - 01.04.2025, 08:26
RE: Modbus profiles examples - by Daniel - 01.04.2025, 08:40
LG AWHP Modbus RTU Profile - by KoBra - 08.04.2023, 13:16
RE: Modbus profiles examples - by AEK - 25.09.2023, 19:11
RE: Modbus profiles examples - by fabiorusco - 30.09.2023, 09:57
RE: Modbus profiles examples - by tomnord - 30.09.2023, 15:25
NIBE S1155 Modbus profile - by merel - 25.01.2024, 09:46
RE: Modbus profiles examples - by Tuwat47 - 16.07.2024, 08:02
RE: Modbus profiles examples - by epps - 23.09.2024, 07:42
RE: Modbus profiles examples - by Novodk - 20.11.2024, 13:31
Huawey Modbus TCP json - by CristianAgata - 06.10.2024, 13:02
RE: Huawey Modbus TCP json - by CristianAgata - 05.01.2025, 10:42
RE: Huawey Modbus TCP json - by atomi23 - 09.01.2025, 16:19
RE: Huawey Modbus TCP json - by CristianAgata - 09.01.2025, 16:28
RE: Huawey Modbus TCP json - by atomi23 - 09.01.2025, 16:32
RE: Modbus profiles examples - by Tuwat47 - 25.10.2024, 06:48
RE: Modbus profiles examples - by admin - 21.11.2024, 13:37
RE: Modbus profiles examples - by Ranjeet - 22.05.2025, 20:05
RE: Modbus profiles examples - by Daniel - 13.01.2025, 08:52
RE: Modbus profiles examples - by AlexLV - 12.02.2025, 21:09
RE: Modbus profiles examples - by FatMax - 17.03.2025, 13:38
RE: Modbus profiles examples - by Ranjeet - 31.03.2025, 12:03
RE: Modbus profiles examples - by Daniel - 31.03.2025, 12:50
RE: Modbus profiles examples - by kgroenhoej - 06.04.2025, 15:09
RE: Modbus profiles examples - by nhemtman - 15.04.2025, 12:46
RE: Modbus profiles examples - by Daniel - 15.04.2025, 12:48
RE: Modbus profiles examples - by nhemtman - 28.04.2025, 05:48
RE: Modbus profiles examples - by Daniel - 28.04.2025, 07:20
RE: Modbus profiles examples - by admin - 28.04.2025, 12:12
RE: Modbus profiles examples - by admin - 23.05.2025, 06:28
RE: Modbus profiles examples - by ALEJANDRO - 25.02.2026, 15:57
RE: Modbus profiles examples - by Daniel - 25.02.2026, 16:00
RE: Modbus profiles examples - by ALEJANDRO - 26.02.2026, 07:17
RE: Modbus profiles examples - by AEK - 26.02.2026, 07:35
RE: Modbus profiles examples - by ALEJANDRO - 04.03.2026, 15:40
RE: Modbus profiles examples - by ALEJANDRO - 15.04.2026, 11:17
RE: Modbus profiles examples - by admin - 15.04.2026, 11:24
RE: Modbus profiles examples - by ALEJANDRO - 15.04.2026, 12:30
