User Access Log on Vis
(06.05.2022, 08:26)admin Wrote: Via .lp file:
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <link rel="stylesheet" href="/apps/css/bootstrap.css"> </head> <body> <table class="table table-striped"> <tr>   <th>Date/time</th>   <th>Login</th>   <th>Name</th>   <th>IP</th> </tr> <? require('apps') items = db:getall([[   SELECT user_logs.*, users.name   FROM user_logs   JOIN users ON user_logs.login=users.login   ORDER BY user_logs.id DESC   LIMIT 50 ]]) for _, item in ipairs(items) do   cls = toboolean(item.failed) and 'danger' or 'success'   datetime = os.date('%Y.%m.%d %H:%M:%S', item.created) ?> <tr class="<?=cls?>">   <td><?=datetime?></td>   <td><?=escape(item.login)?></td>   <td><?=escape(item.name)?></td>   <td><?=escape(item.ip)?></td> </tr> <? end ?> </table> </body> </html>
 Many thanks for your help
User Access Log on Vis - by sjfp - 03.05.2022, 08:38
RE: User Access Log on Vis - by admin - 06.05.2022, 08:26
RE: User Access Log on Vis - by sjfp - 06.05.2022, 13:43
RE: User Access Log on Vis - by khalil - 07.05.2022, 09:57
RE: User Access Log on Vis - by khalil - 08.05.2022, 15:47
RE: User Access Log on Vis - by CristianAgata - 30.06.2026, 12:56
RE: User Access Log on Vis - by admin - 30.06.2026, 16:56
RE: User Access Log on Vis - by CristianAgata - 30.06.2026, 17:13
