02.06.2022, 10:12
I carried out the test of separating the CAN DALI gateways with an independent power supply for each one with the same result. The same gateway (number 2) ends up disconnecting from the CAN bus
The Can bus wiring leaves two lines directly from LM where you also connect the LINE termination, one bus goes directly to a dali gateway (number 1) with a distance of about 20 meters and the other bus that joins the two remaining gateways (number 2 and 3) will have a distance of at least 35 meters.
For one of the buses, a 2-pair KNX bus cable was used.
About how to identify if the ballasts are not compatible, do we have a way to know through the error?
