Staircase script with dimming option
(09.06.2022, 15:33)admin Wrote: Post your full script listing. Also enable logging for mapped object and see if they change values. Check Error logs as well.
Thanks. Here is my answer:
Sorry for not noticing the error log. There are errors:
Resident script:19: attempt to compare nil with number
stack traceback:
Resident script:19: in function 'setinputvalue'
Resident script:54: in function <Resident script:47>
Library localbus: in function ''
Library localbus: in function 'loop'
'1/1/7' is the object of the dimming value.
I have logged 1/1/7. No logs registered.
if not client then   timers = {     {       input = '9/0/1', -- binary PIR status       output = '1/1/7', -- dimmer control (0..100%)       onvaluehigh = 90, -- high output value in %       onvaluelow = 10, -- low output value in %       timeout = 5, -- in seconds     }   }   function setinputvalue(timer, event)     local value = busdatatype.decode(event.datahex, dt.bool)     if not value then       return     end     if timer.value < timer.onvaluelow then       value = timer.onvaluelow     elseif timer.outvalue < timer.onvaluehigh then       value = timer.onvaluehigh     else       value = nil     end     if not timer.ticks and value then       grp.write(timer.output, value, dt.scale)     end     timer.ticks = timer.timeout   end   function setoutputvalue(timer, event)     timer.outvalue = busdatatype.decode(event.datahex, dt.scale)     timer.ticks = nil -- stop timer   end   for _, timer in ipairs(timers) do     timer.outvalue = grp.getvalue(timer.output)   end   sender = 'tm'   grp.sender = sender   client = require('localbus').new(0.1)   client:sethandler('groupwrite', function(event)     if event.sender == sender then       return     end     for _, timer in ipairs(timers) do       if timer.input == event.dst then         setinputvalue(timer, event)       elseif timer.output == event.dst then         setoutputvalue(timer, event)       end     end   end) end client:loop(1) for _, timer in ipairs(timers) do   if timer.ticks then     timer.ticks = timer.ticks - 1     if timer.ticks == 0 then       grp.write(timer.output, timer.outvalue, dt.scale)       timer.ticks = nil     end   end end
RE: Staircase script with dimming option - by Dirk79 - 11.06.2022, 15:28
