Staircase script with dimming option
(13.06.2022, 07:00)admin Wrote: Line 19 should have timer.outvalue instead of timer.value:
if timer.outvalue < timer.onvaluelow then
Thanks for reaction. I have changed this, but error is the same:
if not client then   timers = {     {       input = '9/0/1', -- binary PIR status       output = '1/1/7', -- dimmer control (0..100%)       onvaluehigh = 90, -- high output value in %       onvaluelow = 10, -- low output value in %       timeout = 5, -- in seconds     }   }   function setinputvalue(timer, event)     local value = busdatatype.decode(event.datahex, dt.bool)     if not value then       return     end         if timer.outvalue < timer.onvaluelow then       value = timer.onvaluelow     elseif timer.outvalue < timer.onvaluehigh then       value = timer.onvaluehigh     else       value = nil     end     if not timer.ticks and value then       grp.write(timer.output, value, dt.scale)     end     timer.ticks = timer.timeout   end   function setoutputvalue(timer, event)     timer.outvalue = busdatatype.decode(event.datahex, dt.scale)     timer.ticks = nil -- stop timer   end   for _, timer in ipairs(timers) do     timer.outvalue = grp.getvalue(timer.output)   end   sender = 'tm'   grp.sender = sender   client = require('localbus').new(0.1)   client:sethandler('groupwrite', function(event)     if event.sender == sender then       return     end     for _, timer in ipairs(timers) do       if timer.input == event.dst then         setinputvalue(timer, event)       elseif timer.output == event.dst then         setoutputvalue(timer, event)       end     end   end) end client:loop(1) for _, timer in ipairs(timers) do   if timer.ticks then     timer.ticks = timer.ticks - 1     if timer.ticks == 0 then       grp.write(timer.output, timer.outvalue, dt.scale)       timer.ticks = nil     end   end end
Resident script:19: attempt to compare nil with number
stack traceback:
 Resident script:19: in function 'setinputvalue'
 Resident script:54: in function <Resident script:47>
 Library localbus: in function ''
Libbrarary localbus: in function 'loop'
RE: Staircase script with dimming option - by Dirk79 - 13.06.2022, 19:50
