TCP Socket Connection for Legrand
#26
Hi, I made several attempts to control the MX200 with a script, but unfortunately failed. I have the following commands on the line:
MH200 26.04.2022 19:53:58     * string: *1*9*11##    90%           MH200 26.04.2022 19:54:15     * string: *1*1000#0*11##    OK           MH200 26.04.2022 19:54:15     * string: *1*0*11##    OFF
could you help me to bind them in a script so that I can recognize them on arrival and bind them to the respective objects and accordingly if the value of the object changes I send the command back to the gateway?
This is the code I use to get them in the log:
function read(sock)   local buf = {}   while true do     local ch, err = sock:receive(1)     if ch then       local pr = buf[ #buf ]       buf[ #buf + 1 ] = ch       if ch == '#' and pr == '#' then         break       end     else       return nil, err     end   end   local ret = table.concat(buf)   log(ret)   return ret end -- init socket if not sock then   require('socket')   sock, err = socket.connect('192.168.1.247', 20000)   -- set timeout to 1 second   if sock then     sock:settimeout(1)   -- error opening connection, log error and wait before reconnecting    else     error(err)     sleep(5)   end end -- socket handler if sock then    sock:send('*99*1##')    res, err = read(sock)     if data then     log(data)   end end
RE: TCP Socket Connection for Legrand - by a455115 - 14.06.2022, 06:45
