Staircase script with dimming option
The same script works for me. Does 9/0/1 exist?
I've added some logging, check what you get in the Logs tab:
if not client then   timers = {     {       input = '9/0/1', -- binary PIR status       output = '1/1/7', -- dimmer control (0..100%)       onvaluehigh = 90, -- high output value in %       onvaluelow = 10, -- low output value in %       timeout = 5, -- in seconds     }   }   function setinputvalue(timer, event)     local value = busdatatype.decode(event.datahex, dt.bool)     if not value then       return     end     log('pir trigger', timer.outvalue)     if timer.outvalue < timer.onvaluelow then       value = timer.onvaluelow     elseif timer.outvalue < timer.onvaluehigh then       value = timer.onvaluehigh     else       value = nil     end     if not timer.ticks and value then       grp.write(timer.output, value, dt.scale)     end     timer.ticks = timer.timeout   end   function setoutputvalue(timer, event)     timer.outvalue = busdatatype.decode(event.datahex, dt.scale)     timer.ticks = nil -- stop timer     log('output change', timer.outvalue)   end   for _, timer in ipairs(timers) do     timer.outvalue = grp.getvalue(timer.output)     log('timer init', timer.outvalue)   end   sender = 'tm'   grp.sender = sender   client = require('localbus').new(0.1)   client:sethandler('groupwrite', function(event)     if event.sender == sender then       return     end     for _, timer in ipairs(timers) do       if timer.input == event.dst then         setinputvalue(timer, event)       elseif timer.output == event.dst then         setoutputvalue(timer, event)       end     end   end) end client:loop(1) for _, timer in ipairs(timers) do   if timer.ticks then     timer.ticks = timer.ticks - 1     if timer.ticks == 0 then       log('timer stop', timer.outvalue)       grp.write(timer.output, timer.outvalue, dt.scale)       timer.ticks = nil     end   end end
RE: Staircase script with dimming option - by admin - 15.06.2022, 09:44
