Can not change parameter visparams when using grp.create
.lua   51.lua (Size: 2.74 KB / Downloads: 3)
 I have a homeLynk HW 1.2 , Firmware 1.5.1 in operation for 7 years and now I have implemented scripts to read data from  a Kostal inverte Plenticore plus.
Had succes to read all 125 data point by Modbus TCP. I have generated all KNX Objekts by scripts and it works while using the essetial KNX object parameter with
grp.create.
myobject = grp.create({
    datatype = dt.float32,
    address = Gruppenaddresse,
    name = "Test float32 und visparams",
    units = " W",
    tags =  "Plenticore",
    visparams=grp_visparams
But I am failing to change the visualisation parameter  with the table of visparams.
After creating the object I read its parameter with
log("Grp lesen",grp.find(Gruppenaddresse))
but do not see the table visparams in the log
Changing the visu parameter manually and  do a
Now I have suuccess I got the string of visparams as json.
I have attached the script 51.lua with the lua code that is showing the described behaviour.
Need some information if it possible to change visparams by script using my HW/SW combination.
Can not change parameter visparams when using grp.create - by Fish56 - 12.07.2022, 15:21
