15.07.2022, 13:43
(15.07.2022, 13:32)Fahd Wrote: Hi,
I have a 2-byte unsigned integer object that I have mapped from an AHU that works with Modbus TCP/IP,
However, the object works totally fine only from the object list I can send/read the value and the ahu communicate with that perfectly BUT it's not the case from the supervision interface,
I have created several icons and each icon will send a value 0,1,2,3,4
press icon 1 will send 0
press icon 2 it should send 1 but when I press it sends 4 !
icon 3 work fine
icon 4 work fine
icon 5 works fine
As you can see in the attachment the icon should send a fixed value "1"
I'm totally an idiot, I deleted that icon more than 5 times before posting in the forum and each time I do not click on save
Thank you.
Is there any limitation on the number of Modbus TCP/IP points that we could map?
