SMS - Twilio
(02.08.2022, 10:37)admin Wrote: As I've said - check what you get in logs. Do you get 3 log entries for each script call?
My mistake I thought that  I wrote  the log in the last  reply
This is the log
* arg: 1   * string: {"sid": "SMe1cacb01d1aa4fcea936f4d327e76665", "date_created": "Tue, 02 Aug 2022 10:41:58 +0000", "date_updated": "Tue, 02 Aug 2022 10:41:58 +0000", "date_sent": null, "account_sid": "AC202051b89229eb902d1f8c9807535086", "to": "+4741249991", "from": "+13253264263", "messaging_service_sid": null, "body": "Sent from your Twilio trial account - Alarm HCWC 009 changed to Alarm ON", "status": "queued", "num_segments": "1", "num_media": "0", "direction": "outbound-api", "api_version": "2010-04-01", "price": null, "price_unit": "USD", "error_code": null, "error_message": null, "uri": "/2010-04-01/Accounts/AC202051b89229eb902d1f8c9807535086/Messages/SMe1cacb01d1aa4fcea936f4d327e76665.json", "subresource_uris": {"media": "/2010-04-01/Accounts/AC202051b89229eb902d1f8c9807535086/Messages/SMe1cacb01d1aa4fcea936f4d327e76665/Media.json"}} * arg: 2   * number: 201 * arg: 3   * table:    ["x-powered-by"]     * string: AT-5000    ["twilio-request-duration"]     * string: 0.119    ["strict-transport-security"]     * string: max-age=31536000    ["access-control-allow-headers"]     * string: Accept, Authorization, Content-Type, If-Match, If-Modified-Since, If-None-Match, If-Unmodified-Since    ["twilio-request-id"]     * string: RQ947f026c47551c93614e38b920f3c517    ["x-api-domain"]     * string: api.twilio.com    ["twilio-concurrent-requests"]     * string: 1    ["access-control-expose-headers"]     * string: ETag    ["content-type"]     * string: application/json    ["connection"]     * string: close    ["content-length"]     * string: 835    ["x-shenanigans"]     * string: none    ["access-control-allow-origin"]     * string: *    ["date"]     * string: Tue, 02 Aug 2022 10:41:58 GMT    ["access-control-allow-methods"]     * string: GET, POST, DELETE, OPTIONS    ["access-control-allow-credentials"]     * string: true    ["x-home-region"]     * string: us1
As I told you the 3 numbers are the same (till now I will change it the I update the account), I can send the message 3 times if  copy and past  the code in below 3 times with the same number  but it didn't work with the loop for
from_nr = '+13253264263' -- put sender SIM nr here
to_nr = '' -- put recepient SIM nr here
id_nr = '' -- put your ID here
token_nr = '' -- put your token here
sms(id_nr, token_nr, from_nr, to_nr, 'Alarm HCWC 009 changed to Alarm OFF')
SMS - Twilio - by Fahd - 02.08.2022, 06:24
RE: SMS - Twilio - by admin - 02.08.2022, 07:47
RE: SMS - Twilio - by Fahd - 02.08.2022, 08:23
RE: SMS - Twilio - by admin - 02.08.2022, 08:41
RE: SMS - Twilio - by Fahd - 02.08.2022, 09:53
RE: SMS - Twilio - by admin - 02.08.2022, 09:57
RE: SMS - Twilio - by Fahd - 02.08.2022, 10:18
RE: SMS - Twilio - by admin - 02.08.2022, 10:37
RE: SMS - Twilio - by Fahd - 02.08.2022, 10:54
RE: SMS - Twilio - by admin - 02.08.2022, 11:38
RE: SMS - Twilio - by Fahd - 02.08.2022, 11:46
RE: SMS - Twilio - by admin - 02.08.2022, 12:05
RE: SMS - Twilio - by Fahd - 02.08.2022, 12:23
