SMS - Twilio
This might happen because you are sending a message with the same text. Twilio accepts the message but then fails with "Unknown error"/undelivered. If you log the Twilio response you can check the message status in your browser by accessing https://api.twilio.com/2010-04-01/Accoun...GE_ID.json ("uri" part of the returned JSON by Twilio). Use your id/token as username/password.
Your script can be optimized like this:
value = event.getvalue() if value then   text = 'Alarm HCWC 009 changed to Alarm ON' else   text = 'Alarm HCWC 009 changed to Alarm OFF' end from_nr = '+***' to_nrs = { '+***', '+***', '+***' } id_nr = '***' -- put your ID here token_nr = '***' -- put your token here for _, to_nr in ipairs(to_nrs) do   sms(id_nr, token_nr, from_nr, to_nr, text) end
SMS - Twilio - by Fahd - 02.08.2022, 06:24
RE: SMS - Twilio - by admin - 02.08.2022, 07:47
RE: SMS - Twilio - by Fahd - 02.08.2022, 08:23
RE: SMS - Twilio - by admin - 02.08.2022, 08:41
RE: SMS - Twilio - by Fahd - 02.08.2022, 09:53
RE: SMS - Twilio - by admin - 02.08.2022, 09:57
RE: SMS - Twilio - by Fahd - 02.08.2022, 10:18
RE: SMS - Twilio - by admin - 02.08.2022, 10:37
RE: SMS - Twilio - by Fahd - 02.08.2022, 10:54
RE: SMS - Twilio - by admin - 02.08.2022, 11:38
RE: SMS - Twilio - by Fahd - 02.08.2022, 11:46
RE: SMS - Twilio - by admin - 02.08.2022, 12:05
RE: SMS - Twilio - by Fahd - 02.08.2022, 12:23
