Ebeco floorheat thermostat
(08.08.2022, 06:04)admin Wrote: Use this:
function GetToken()   local response_body = {}   local request_body = json.encode({     userNameOrEmailAddress = userNameOrEmailAddress,     password = password,   })   local body, code, hdrs, stat = ssl.https.request{     url = 'https://ebecoconnect.com/api/TokenAuth/Authenticate',     method = 'POST',     headers = {       ['Content-Type'] = 'application/json',       ['Content-Length'] = #request_body,       ['Abp.TenantId'] = 1,     },     source = ltn12.source.string(request_body),     sink = ltn12.sink.table(response_body),   }   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     log(ret)     return ret.access_token -- could be some other field, try to log ret to be sure   else     log('request failed', body, code, hdrs, stat)   end end
The request_url in RequestFromEbeco is wrong, it should be "https://ebecoconnect.com/api/services/app/Devices/GetUserDevices" (without any additional parameters).
Thanks, but did´nt get that to work either. But change my script line from having ". . ." to '. . .'
Then I put in log('request failed') and got this in response:
Ebeco REST API copy 08.08.2022 08:48:58
* arg: 1
  * string: request failed
* arg: 2
  * number: 1
* arg: 3
  * number: 415
* arg: 4
  * table:
  ["server"]
    * string: Microsoft-IIS/10.0
  ["connection"]
    * string: close
  ["content-length"]
    * string: 0
  ["x-rate-limit-limit"]
    * string: 60s
  ["x-rate-limit-remaining"]
    * string: 29
  ["request-context"]
    * string: appId=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  ["x-frame-options"]
    * string: SAMEORIGIN
  ["x-rate-limit-reset"]
    * string: 2022-08-08T06:49:58.5482160Z
  ["date"]
    * string: Mon, 08 Aug 2022 06:48:57 GMT
  ["x-xss-protection"]
    * string: 1; mode=block
  ["set-cookie"]
    * string: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxPath=/;HttpOnly;SameSite=None;Secure;Domain=ebecoconnect.com
  ["x-content-type-options"]
    * string: nosniff
* arg: 5
  * string: HTTP/1.1 415 Unsupported Media Type
I added the X:es if it might have been sensitive stuff Smile
Ebeco floorheat thermostat - by victor.back - 17.12.2021, 06:50
RE: Ebeco floorheat thermostat - by admin - 17.12.2021, 07:42
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 06:04
RE: Ebeco floorheat thermostat - by victor.back - 08.08.2022, 06:56
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 07:06
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 07:24
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 08:01
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 09:27
RE: Ebeco floorheat thermostat - by admin - 08.08.2022, 12:07
RE: Ebeco floorheat thermostat - by admin - 31.10.2023, 07:57
