MqTT in Wiser for KNX
(26.08.2022, 10:38)admin Wrote: If you don't have a lot of frequent updates you can use event script to publish new values then disconnect.
Add to Common functions and change username/password:
function mqttpublish(topic, data)   local broker = 'mqtt.eniris.be'   local username = 'xxx'   local password = 'xxx'   local port = 1883   local mqtt = require('mosquitto')   local client = mqtt.new()   if type(data) == 'table' then     data = require('json').encode(data)   end   client.ON_CONNECT = function(status, rc, msg)     if status then       log('mqtt cloud connected')       client:publish(topic, data)     else       log('mqtt cloud connect failed ' .. tostring(msg))       client:disconnect()     end   end   client.ON_PUBLISH = function()     log('disconnecting')     client:disconnect()   end   client:login_set(username, password)   local status, rc, msg = client:connect(broker, port)   if status then     client:loop_forever()   else     log('cloud connect failed: ' .. tostring(msg))   end end
Event script example:
topic = 'Actual Temp/Hal A/S2' data = {   time = os.time(),   extraTags = {     subId = 'T19'   },   fields = {     temperature_degC = event.getvalue()   } } mqttpublish(topic, data)
Hello Admin,
Thank you for the quick reply.
Unfortunately I will have to publish around 200 objects and its not that they come in the bus very frequently.
Is there and option to publish data every one minute? Like adding a resident script with sleep internal of 1min?
Regards,
MqTT in Wiser for KNX - by JRP - 20.05.2020, 12:11
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 12:40
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 13:55
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 13:59
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 18:34
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 07:21
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 10:40
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 10:42
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:20
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:22
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:47
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:50
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 15:28
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 10:38
RE: MqTT in Wiser for KNX - by manos@dynamitec - 26.08.2022, 10:58
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 11:06
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 12:55
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:18
RE: MqTT in Wiser for KNX - by admin - 19.05.2023, 10:24
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:42
RE: MqTT in Wiser for KNX - by JRP - 20.05.2023, 17:10
RE: MqTT in Wiser for KNX - by admin - 22.05.2023, 06:52
RE: MqTT in Wiser for KNX - by JRP - 26.05.2023, 08:21
