FB Editor Staircase Lighting Function
You need to add 'Filter' Filtr On-On / Off-__ between the outbut from your 'Lock out' and the input of your Stairase lighting function.
When you use this it only sent a 1 and never sent a 0.
the help says about input 1:
Start of the module by a telegram with the value not equal to zero. Output 1 has a one for the duration. If this input receives a zero, then Output 1 switches to zero.
i did made a script and do the same, but it also checks if the doors are closed, it all the doors are closed, then it goes off, if not, it stay on.
*at my script, more doors enable the lights, but not at all doors are the check if it is closed.
but it is a script, not blockly like you used.
--Read current status/value deur_berging = grp.getvalue('14/0/57')            --'Deur Berging' Garage_loopdeur = grp.getvalue('14/0/65')        --'Garage Loopdeur' Poort = grp.getvalue('14/0/45')                --'Poort Buiten' Schemering = grp.getvalue('5/0/9')            --'Schemering' Buitenlamp_achterdeur = grp.getvalue('1/4/162')        --'B verl. Achterdeurlamp (tm)'     --if one of these go open, set light on if (deur_berging or Garage_loopdeur or Poort == true)         and Buitenlamp_achterdeur == false         and Schemering < 200 then grp.checkwrite('1/1/162', true)            --'B verl. Achterdeurlamp (s)' end os.sleep (300)                        --wacht voor 300 seconden (5 minuten) repeat    -- repeat all below till 'Buitenlamp_achterdeur' is off         --Read current status/value (find because update time, doenst work with getvalue deur_berging =         grp.find('14/0/57')            --'Deur Berging' Garage_loopdeur =     grp.find('14/0/65')            --'Garage Loopdeur' Poort =         grp.find('14/0/45')            --'Poort Buiten' --calculate the time differents between now and last time of a true now = os.time()                                -- current timestamp in seconds delta_deur_berging    = now - deur_berging.updatetime         -- last object update relative time delta_Garage_loopdeur     = now - Garage_loopdeur.updatetime         -- last object update relative time delta_Poort         = now - Poort.updatetime             -- last object update relative time --Read current status/value get_deur_berging =     grp.getvalue('14/0/57')            --'Deur Berging' get_Garage_loopdeur =     grp.getvalue('14/0/65')            --'Garage Loopdeur' get_Poort =         grp.getvalue('14/0/45')            --'Poort Buiten' Buitenlamp_achterdeur = grp.getvalue('1/4/162')            --'B verl. Achterdeurlamp (tm)'             --if all is closed for set time turn light off if         delta_deur_berging >    (1 * 60 ) -- minuten        -- controleer of de PIR niet meer actief is geweest voor de laatste 1 minuut         and     delta_Garage_loopdeur >    (1 * 60 ) -- minuten        -- controleer of de PIR niet meer actief is geweest voor de laatste 1 minuut         and     delta_Poort >        (1 * 60 ) -- minuten        -- controleer of de PIR niet meer actief is geweest voor de laatste 1 minuut         and get_deur_berging == false         and get_Garage_loopdeur == false         and get_Poort == false                 and Buitenlamp_achterdeur == true then    grp.checkwrite('1/1/162', false)            --'B verl. Achterdeurlamp (s)' end os.sleep (120)                        --wacht voor 120 seconden (2 minuten) Buitenlamp_achterdeur = grp.getvalue('1/4/162')        --'B verl. Achterdeurlamp (tm)'     until (Buitenlamp_achterdeur == false)
RE: FB Editor Staircase Lighting Function - by Dré - 11.09.2022, 15:37
