massive data logging
You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
Try replacing lines 35..42 with this:
local body if type(value) == 'boolean' or type(value) == 'number' then   body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value) elseif type(value) == 'string' then   body = string.format('%s,name=%s,addr=%s value=%q', table, name, addr, value) else   log('invalid data type', addr, type(value))   return end
Currently this script sends values for all objects. There should be some filtering implemented so only the required data is pushed.
massive data logging - by gdimaria - 05.09.2022, 16:22
RE: massive data logging - by admin - 06.09.2022, 10:08
RE: massive data logging - by gdimaria - 07.09.2022, 07:42
RE: massive data logging - by admin - 07.09.2022, 07:47
RE: massive data logging - by gdimaria - 14.09.2022, 11:14
RE: massive data logging - by admin - 14.09.2022, 11:33
RE: massive data logging - by gdimaria - 15.09.2022, 09:05
RE: massive data logging - by admin - 15.09.2022, 09:23
RE: massive data logging - by gdimaria - 15.09.2022, 10:04
RE: massive data logging - by admin - 15.09.2022, 12:55
RE: massive data logging - by gdimaria - 16.09.2022, 10:26
RE: massive data logging - by admin - 19.09.2022, 06:10
