trend export via csv
Can you confirm that this script by erwin Van der Zwart that i adapted allows you to send all the trends to a remote FTP server?
--**************************************************************************-- --** Email trendlog data as CSV attachment created by Erwin van der Zwart **-- --************ For HL from FW 1.5 and SL from FW 1.2 with NGINX ************-- --**************************************************************************-- --*************************** Start of parameters **************************-- -- Version 1.1 *************************************************************-- --Mettre la valeur true pour exporter l'ensemble des courbes : export_all = true -- mettre le noms de chaque courbes que vous souhaitez exporter (Seulement utilisé quand : export_all = false) trendnames = {   "Total Electric Usage",   "Total Water Usage",   "Total Gas Usage", } require('trends') trends_table = db:getall('SELECT name FROM trends ORDER BY name DESC') if export_all == false then     i = 1     for _, trend_names in ipairs(trends_table) do     delete_from_table = true         for _, trendname in ipairs(trendnames) do       if trendname == trend_names.name then             delete_from_table = false       end     end     if delete_from_table == true then       table.remove(trends_table, i)       end       i = i + 1   end end if #trends_table < 1 then   log("No trends available, Could not export trends")   return end buffer = {} table.insert(buffer, '"This file contains the export data of ' .. #trends_table .. ' trend(s) and is automaticly created on ' .. os.date("%A",os.time()) .. ' ' .. os.date("%d-%m-%y at %H:%M") .. '"') table.insert(buffer, '""') local months = { "Januari", "Februari", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December" } for _, trend_names in ipairs(trends_table) do     trend_name = trend_names.name       table.insert(buffer, '"##### START OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')     table.insert(buffer, '""')   timestamp = os.time()     startpoint = os.date('*t', timestamp)     endpoint = os.date('*t')         startpoint.sec = 0     startpoint.min = 0     startpoint.hour = 0     startpoint.yday = startpoint.yday - (startpoint.day -1)     startpoint.day = 1     startpoint.wday = 1     endpoint.sec = 0     endpoint.min = 0     endpoint.hour = 0     endpoint.yday = endpoint.yday - (endpoint.day -1)     endpoint.day = 1     endpoint.wday = 1         dates = {}   dates['start'] = startpoint     if dates['start'].month == 1 then       dates['start'].month = 12     dates['start'].year = dates['start'].year - 1   else     dates['start'].month = dates['start'].month - 1   end     dates['end'] = endpoint   dates['end'].month = dates['start'].month + 1       resolution = 86400       trenddatamonth = trends.fetch(trend_name, dates, resolution)       trenddatamonthavg = trends.fetchone(trend_name, dates, resolution)       table.insert(buffer, '"Export of the average usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')     table.insert(buffer, '""')     table.insert(buffer, '"Start date","End Date","Average month value"')     table.insert(buffer, '"01-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. #trenddatamonth .. '-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. trenddatamonthavg .. '"')     table.insert(buffer, '""')     table.insert(buffer, '"Detailed export of the daily usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')     table.insert(buffer, '""')     table.insert(buffer, '"Weekday","Date","Average day value"')   for _, row in ipairs(trenddatamonth) do     stamp = dates['start'].year .. '-' .. dates['start'].month .. '-' .. string.format("%02d", _)         local y, m, d = stamp:match("(%d+)%-(%d+)%-(%d+)")         local t = { year = y, month = m, day = d}          csv = string.format('%q,%q,%q', os.date("%A",os.time(t)), "" .. string.format("%02d", _) .. "-" .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year, row)         table.insert(buffer, csv)   end     table.insert(buffer, '""')     table.insert(buffer, '"##### END OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')     table.insert(buffer, '""') end src = 'Trend Export '.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer) local ftp = require("socket.ftp") local ltn12 = require("ltn12") -- Indiquer le dossier du serveur FTP dans lequel vous souhaitez mettre le fichier CSV des courbes target = '/EXPORT/Courbes/' .. src --Indiquer HOST / USER / PASSWORD f, e = ftp.put{   host = "192.168.54.246",   user = "FTP-User",   password = "my_password",   type = "i",   argument = target,   source = ltn12.source.file(io.open(dst, "rb"))   } if (e) then   log (e)   log (f)   alert("Could not ftp: ", e, "\n") end log("ftp_trends") os.remove(dst)
Thank you for your understanding.
Best regards.
trend export via csv - by PassivPluss - 19.10.2016, 19:12
RE: trend export via csv - by PassivPluss - 19.10.2016, 20:03
RE: trend export via csv - by benanderson_475 - 10.12.2019, 19:39
RE: trend export via csv - by Gadjoken - 19.09.2022, 07:43
RE: trend export via csv - by Trond Hoyem - 16.01.2023, 14:03
RE: trend export via csv - by admin - 16.01.2023, 14:12
RE: trend export via csv - by Trond Hoyem - 16.01.2023, 14:18
RE: trend export via csv - by admin - 16.01.2023, 14:20
RE: trend export via csv - by Trond Hoyem - 16.01.2023, 14:31
