Astronomical clock
Hi Josep,
Make sure this function is inside common functions:
-- sunrise / sunset calculation function rscalc(latitude, longitude, when)  local pi = math.pi  local doublepi = pi * 2  local rads = pi / 180.0  local TZ = function(when)    local ts = os.time(when)    local utcdate, localdate = os.date('!*t', ts), os.date('*t', ts)    localdate.isdst = false    local diff = os.time(localdate) - os.time(utcdate)    return math.floor(diff / 3600)  end  local range = function(x)    local a = x / doublepi    local b = doublepi * (a - math.floor(a))    return b < 0 and (doublepi + b) or b  end  when = when or os.date('*t')  local y2k = { year = 2000, month = 1, day = 1 }  local y2kdays = os.time(when) - os.time(y2k)  y2kdays = math.ceil(y2kdays / 86400)  local meanlongitude = range(280.461 * rads + 0.9856474 * rads * y2kdays)  local meananomaly = range(357.528 * rads + 0.9856003 * rads * y2kdays)  local lambda = range(meanlongitude + 1.915 * rads * math.sin(meananomaly) + rads / 50 * math.sin(2 * meananomaly))  local obliq = 23.439 * rads - y2kdays * rads / 2500000  local alpha = math.atan2(math.cos(obliq) * math.sin(lambda), math.cos(lambda))  local declination = math.asin(math.sin(obliq) * math.sin(lambda))  local LL = meanlongitude - alpha  if meanlongitude < pi then    LL = LL + doublepi  end  local dfo = pi / 216.45  if latitude < 0 then    dfo = -dfo  end  local fo = math.min(math.tan(declination + dfo) * math.tan(latitude * rads), 1)  local ha = 12 * math.asin(fo) / pi + 6  local timezone = TZ(when)  local equation = 12 + timezone + 24 * (1 - LL / doublepi) - longitude / 15  local sunrise, sunset = equation - ha, equation + ha  if sunrise > 24 then    sunrise = sunrise - 24  end  if sunset > 24 then    sunset = sunset - 24  end  return math.floor(sunrise * 60), math.ceil(sunset * 60) end
Then create a resident script with time 60 seconds and add this code:
-- ***** Astronomic clock module Version 1.0 Created by Erwin van der Zwart ***** -- -- ********* Use this script as resident script and run every 60 seconds ******** -- -- ****** This script makes use of rscalc function inside common functions ****** -- -- ******************************** SET PARAMETERS ****************************** -- -- Set output address adressoutput = '1/1/1' -- 1 bit output for control object -- Set time shifting addresses addressshifttimesunrice = '1/1/2' -- 1 or 2 byte signed integer to be able to adjust/offset calculated sunrise time (set min/max on object) addressshifttimesundown = '1/1/3'-- 1 or 2 byte signed integer to be able to adjust/offset calculated down time (set min/max on object) -- Set feedback adresses addresssunrise = '1/1/4' -- 255 byte object for user feedback, shows calculated sunrise time addresssundown = '1/1/5' -- 255 byte object for user feedback, shows calculated sundown time addresssunriseshifted = '1/1/6' -- 255 byte object for user feedback, shows with offset calculated sunrise time addressundownshifted = '1/1/7' -- 255 byte object for user feedback, shows with offset calculatedsundown time -- Set location coordinates latitude = 52.52198 --Zwolle Netherlands, Look at 'http://www.mapcoordinates.net/en' for other locations longitude = 6.08213 --Zwolle Netherlands, Look at 'http://www.mapcoordinates.net/en' for other locations -- ******************************** END PARAMETERS ****************************** -- -- ********************* DON'T CHANGE ANYTHING UNDER THIS LINE ****************** -- -- Function to calculate switching times based and output value function astronomic(latitude,longitude,shiftedsunrise,shiftedsundown)  local now = os.date('*t')  local sunrise, sunset = rscalc(latitude, longitude, now) --Zwolle Netherlands, See http://www.mapcoordinates.net/en for other locations  sunriseorg = string.format('%d:%.2d', math.floor(sunrise / 60), sunrise % 60)  sunsetorg = string.format('%d:%.2d', math.floor(sunset / 60), sunset % 60)  sunrisenew = sunrise + shiftedsunrise  sunsetnew = sunset + shiftedsundown  sunrisetime = string.format('%d:%.2d', math.floor(sunrisenew / 60), sunrisenew % 60)  sunsettime = string.format('%d:%.2d', math.floor(sunsetnew / 60), sunsetnew % 60)  local minutes = now.hour * 60 + now.min  nowdark = minutes < sunrisenew or sunsetnew < minutes  local t = {sunricenormal = sunriseorg, sundownnormal = sunsetorg, sunriceshifted = sunrisetime, sundownshifted = sunsettime, output = nowdark}    return (t) end -- Get values for timeshifting shiftedsunrise = grp.getvalue(addressshifttimesunrice) or 0 -- Make minutes negative to switch earlyer than normal calculated sunrice and positive to switch later than normal calculated sunrice shiftedsundown = grp.getvalue(addressshifttimesundown) or 0 -- Make minutes negative to switch earlyer than normal calculated sundown and positive to switch later than normal calculated sundown -- Call function to calculate astroinfo astroinfo = astronomic(latitude,longitude,shiftedsunrise,shiftedsundown) -- Set new sunrice time (unshifted) currentvalue = grp.getvalue(addresssunrise) if astroinfo.sunricenormal ~= currentvalue then    grp.update(addresssunrise, astroinfo.sunricenormal) end -- Set new sundown time (unshifted) currentvalue = grp.getvalue(addresssundown) if astroinfo.sundownnormal ~= currentvalue then    grp.update(addresssundown, astroinfo.sundownnormal) end -- Set new sunrice time (shifted) currentvalue = grp.getvalue(addresssunriseshifted) if astroinfo.sunriceshifted ~= currentvalue then    grp.update(addresssunriseshifted, astroinfo.sunriceshifted) end -- Set new sundown time (shifted) currentvalue = grp.getvalue(addressundownshifted) if astroinfo.sundownshifted ~= currentvalue then  grp.update(addressundownshifted, astroinfo.sundownshifted) end -- Set output value to output object currentvalue = grp.getvalue(adressoutput) if astroinfo.output == true then  if currentvalue == false then    grp.write(adressoutput, true)  end else  if currentvalue == true then    grp.write(adressoutput, false)  end end
If you want to combine it with a scheduler then make a 'and' logic, put the output of this script to input 1, output of the schedular to input 2 and the control object to the output of your 'and' logic.
Astronomical clock - by josep - 13.12.2016, 19:01
RE: Astronomical clock - by admin - 13.12.2016, 19:39
RE: Astronomical clock - by Erwin van der Zwart - 13.12.2016, 19:45
RE: Astronomical clock - by Jørn - 13.12.2016, 20:28
RE: Astronomical clock - by Jørn - 13.12.2016, 21:48
RE: Astronomical clock - by davidchispas - 19.07.2021, 08:34
RE: Astronomical clock - by Domoticatorino - 17.11.2022, 09:50
RE: Astronomical clock - by Mihail - 06.03.2017, 18:06
RE: Astronomical clock - by admin - 07.03.2017, 11:43
RE: Astronomical clock - by tuxtof - 08.03.2017, 21:07
RE: Astronomical clock - by buuuudzik - 07.03.2017, 12:07
RE: Astronomical clock - by admin - 09.03.2017, 07:10
RE: Astronomical clock - by admin - 19.07.2021, 09:13
RE: Astronomical clock - by davidchispas - 19.07.2021, 10:03
RE: Astronomical clock - by admin - 19.07.2021, 10:09
RE: Astronomical clock - by davidchispas - 19.07.2021, 10:25
RE: Astronomical clock - by admin - 19.07.2021, 10:29
RE: Astronomical clock - by asgeirsb - 30.06.2022, 13:24
RE: Astronomical clock - by asgeirsb - 01.07.2022, 06:55
RE: Astronomical clock - by asgeirsb - 01.07.2022, 10:03
RE: Astronomical clock - by admin - 30.06.2022, 14:42
RE: Astronomical clock - by asgeirsb - 04.09.2022, 16:08
RE: Astronomical clock - by admin - 05.09.2022, 06:12
