13.12.2016, 21:48
(13.12.2016, 21:08)Erwin van der Zwart Wrote: Hi,
Did you create the objects mentioned on line 6 and 7?
These are for changing the output times with a offset.
Create them as 1 or 2 byte signed integer so you can set for
example -30 or +45 minutes to the original calculated sunrise/down time.
If you dont want offset set them to 0 but they must excist or you must rewrite script.
I did create the objects, but forgot to write initial value to them, that did the trick!
The time group objects used with datatype "255 byte string".
Thanks alot Erwin!
Br from Jørn.
Best regards, Jørn.
