KNX/IP Disconnected
#27
(17.10.2022, 10:22)admin Wrote: Check Error logs. Connect/disconnect events are added to alerts. KNX errors (Transmitter Error/Temperature Warning) are added to Error logs.
It would make more sense to split the line into two segments via line coupler instead of increasing the power supply maximum current. As I've mentioned before: The more devices are on the KNX line the harder it is to transmit data. This leads to the chip overheating and/or not being able to transmit at all (send 0 receive 1 error).
Yes indeed regarding the alerts I have attached them as pdf. Forgot to attach the errors.
Splitting is my prefered way also but will require more effort and more money for the LC. Anyway thank you for the support, validation of the situation and recomended solution.
Regards,
KNX/IP Disconnected - by Angeles - 06.05.2016, 08:11
RE: KNX/IP Disconnected - by rocfusion - 21.02.2017, 08:26
RE: KNX/IP Disconnected - by admin - 21.02.2017, 08:35
RE: KNX/IP Disconnected - by rocfusion - 22.02.2017, 01:47
RE: KNX/IP Disconnected - by morkovka - 30.08.2021, 20:27
RE: KNX/IP Disconnected - by forsterm - 31.08.2021, 06:36
RE: KNX/IP Disconnected - by morkovka - 31.08.2021, 07:51
RE: KNX/IP Disconnected - by PassivPluss - 21.02.2017, 08:50
RE: KNX/IP Disconnected - by admin - 21.02.2017, 09:35
RE: KNX/IP Disconnected - by PassivPluss - 21.02.2017, 09:37
RE: KNX/IP Disconnected - by admin - 31.08.2021, 07:53
RE: KNX/IP Disconnected - by morkovka - 31.08.2021, 08:28
RE: KNX/IP Disconnected - by admin - 31.08.2021, 08:30
RE: KNX/IP Disconnected - by Hyxion14 - 01.10.2021, 06:27
RE: KNX/IP Disconnected - by admin - 01.10.2021, 06:47
RE: KNX/IP Disconnected - by Hyxion14 - 01.10.2021, 07:53
RE: KNX/IP Disconnected - by morkovka - 01.10.2021, 14:02
RE: KNX/IP Disconnected - by admin - 01.10.2021, 14:06
RE: KNX/IP Disconnected - by morkovka - 05.10.2021, 07:09
RE: KNX/IP Disconnected - by admin - 05.10.2021, 07:13
RE: KNX/IP Disconnected - by myg - 10.10.2021, 08:18
RE: KNX/IP Disconnected - by admin - 12.10.2021, 12:09
RE: KNX/IP Disconnected - by manos@dynamitec - 14.10.2022, 13:53
RE: KNX/IP Disconnected - by admin - 17.10.2022, 06:32
RE: KNX/IP Disconnected - by manos@dynamitec - 17.10.2022, 10:14
RE: KNX/IP Disconnected - by admin - 17.10.2022, 10:22
RE: KNX/IP Disconnected - by manos@dynamitec - 17.10.2022, 10:30
