Common script does not work in the way I want
I have a function called "commpnPost()" in a common script as below.
I call this function everytime when there's a change in each KNX status object, so that I can let other servers know that there's a status change in the KNX project.
I call it in each event script as the image below.   ('9/2/1' is the group address of the status object)
However, when I log the output inside the common script, I can see the first argument '9/2/1' somehow changed to '10/4/5'.
I also made sure that it already changed to '10/4/5' at the first line of the commonPost function.
This happens with other group addresses too.
Am I using common script in a wrong way ? Or maybe there is a chace that I need to clear inside LM ?
function commonPost(add, value)   local dptString  = convertToDptString(add)   local payload = ""   if dptString == "dtDate" then     payload = '{"groupAddress":  "' ..add..'","value": {"dtDate": { "year":' ..tostring(value["year"]).. ', "month": '..tostring(value["month"])..  ', "day": '..tostring(value["day"]).. '}}}'   elseif dptString == "dtTime" then     payload = '{"groupAddress":  "' ..add..'","value": {"dtTime": { "hour":' ..tostring(value["hour"]).. ', "minute": '..tostring(value["minute"])..  ', "second": '..tostring(value["second"]).. '}}}'   else     payload = '{"groupAddress":  "' ..add..'","value": {"'..dptString.. '": ' ..tostring(value).. '}}'   end   log('payload: ', payload)   --**post the payload to a speficic REST endpoint  ** end
function convertToDptString(address)   mapping = {}   for key, value in pairs(dt) do     mapping[ value ] = 'dt' .. string.upper(string.sub(key, 1, 1)) .. string.sub(key, 2)   end   obj = grp.find(address)   dpt = obj.datatype   if dpt then   dtname = mapping[ dpt ]   if not dtname and dpt >= 1000 then     dtname = mapping[ math.floor(dpt / 1000) ]   end end   return dtname end
Common script does not work in the way I want - by Hadeel - 20.10.2022, 22:46
