api, nesting too deep
Nesting limit is needed to prevent recursive tables. Without this limit such code will cause an infinite loop when logging:
t = {} t.t = t log(t)
You can use an external JSON viewer to find which fields you need from the whole JSON table. Keep in mind that Lua indexing starts from 1 instead of 0. This will log the relevant data:
require('json') require('socket.http') url = 'https://ergast.com/api/f1/current/last/results.json' data = socket.http.request(url) data = json.pdecode(data) if type(data) == 'table' then   log(data.MRData.RaceTable.Races) end
api, nesting too deep - by Dré - 30.10.2022, 15:40
RE: api, nesting too deep - by admin - 31.10.2022, 06:57
RE: api, nesting too deep - by Dré - 31.10.2022, 19:41
