(03.11.2022, 11:32)CristianAgata Wrote:(03.11.2022, 09:18)toujour Wrote: Hi,
I'm using a HW3.1 HL and I have this problem with new FW2.8 (device is new, out of the box).
I can't enter in flashsys (check the attachment)
Factory reset and change SD doesn't work.
I have a solution from an image of an other working project (backup and then restore on new SD).....but after some days I receive the same ERROR.
Do you have a definitive solution for me ?
Alberto
Hi Alberto,
Have you tried to connect point to point with the device?
Best regards Cristian
Hi Cristian,
Yes, I was in LAN.
(03.11.2022, 11:42)Daniel Wrote: It is probably a HW issue. Are you saying that in older FW all was fine?
I opened the box and updated to FW2.8
When I saw this problem I plugged a new SD with an other working project --> restore to factory --> updated to FW2.8 --> restore a backup
After some days I saw the same problem.
I never found this problem before (this is the first time with FW2.8)
KNX Advanced Partner + Tutor
