03.01.2017, 15:48
Quote:1. Does websocket server runs at same ip/port with visualisation ?Yes
Quote:2. when we try to listen 1 object; will server push to chaged data or actual data to client ?All bus telegrams are pushed no matter how many objects you listen to
Quote:3. can we listen multiple objects with [ localbus.listen('object', ] notation ?You can have many listeners for each object or use a single telegram listener and filter event by dst group address param
Quote:1. Will everything else keep working if I upgrade to the latest beta firmware?Nobody knows as it's not fully tested yet
Quote:2. Will the websocket code still run in the next official firmware release? (I do not want to reprogram my intranet with every release)Yes
Quote:Can't get this work, what is the name of the .cgi file in the folder you mentioned?The path is http://LM_IP/scada-main/objects/update
