19.01.2023, 11:36
For several temperature sensors you can calculate the average and use it as a source temperature for PID regulator.
PID example: https://openrb.com/example-pid-thermostat-with-lm2/
It requires minor modifications to work with 1 bit output instead of 1 byte: https://forum.logicmachine.net/showthread.php?tid=386
To prevent overheating you can make a separate script that activates PID "manual" object and turns off the valve if the temperature raises above a certain level. The temperature limit depends on many factors like the sensor placement and flooring material.
