HTTP event from camera
(06.02.2023, 12:17)admin Wrote: You can do it like this, alarm_1 will write to 1/1/1, alarm_2 to 1/1/2 and so on.
<? require('apps') vars = getvars() for i = 1, 16 do   if vars['alarm_' .. i] then     grp.write('1/1/' .. i, true)   end end
But you cannot use else clause here because it will reset all other alarms. Either the alarm variable should have some value (like 1/0) or you should check the IP address of the camera that sent this event.
ok, i thank for your help, only one adress i need to write, but log each of event, something like this:
<? require('apps') vars = getvars() for i = 1, 16 do   if vars['alarm_' .. i] then     grp.write('33/2/1', true)   end end log(vars)
it looks to work from each cam
HTTP event from camera - by 2MAX - 06.02.2023, 11:33
RE: HTTP event from camera - by admin - 06.02.2023, 11:54
RE: HTTP event from camera - by 2MAX - 06.02.2023, 12:02
RE: HTTP event from camera - by admin - 06.02.2023, 12:04
RE: HTTP event from camera - by 2MAX - 06.02.2023, 12:10
RE: HTTP event from camera - by admin - 06.02.2023, 12:17
RE: HTTP event from camera - by 2MAX - 06.02.2023, 12:24
