06.02.2023, 18:29
(13.07.2020, 17:54)ro_ki@tut.by Wrote: Attached you can find the library to control LG TV with Web OS.Hi,
It uses Lua websocket library from here https://github.com/lipp/lua-websockets. Websocket library is also available in this forum.
Just change the name of the library to yours in the coding ('user.websocket_client_sync')
It was inspired by Node.JS module https://github.com/hobbyquaker/lgtv2, you can also find a list of commands and configuration instructions there.
Coding is published as is , errors are possible
The following command will turn Off the LG TV . 2 constants below are the IP address of the LG TV and the KNX group address to store the handshake key.
Code:lg_execute_command(LGTV65_IP, LGTV65_KEY, "", "request", "ssap://system/turnOff", "")
Thank you so much for your works, I am working with your script. On WOL I can work with the TV, but with script I always receive (no connection). Is there some initial confirmation to do before start?
Best regards Cristian
