HTTP PUT image to 2N intercom
Hello!
Using a SE spaceLYnk I'm trying to send an image to a 2N IP Verso intercom when the firealarm is activated and remove the image when the fire alarm resets.
The intercom uses HTTPS and Digest authentication.
I've got it working in postman but not from the SpaceLYnk.
I only got the DELETE part working with basic authentication.
-- /img/STOP_DNE_241x320.png (I want to use this) -- /img/fire_241x320.png (Alternate image for testing) fire = grp.getvalue('32/1/1') --log(fire) if fire == true then   log('FIREALARM ACTIVE') -- Send image to intercom -- https://10.0.0.230/api/display/image?display=ext1   elseif fire == false then   log('No fire')   -- Delete image from intercom -- https://10.0.0.230/api/display/image?display=ext1 local https = require("ssl.https") local ltn12 = require("ltn12") local response_body = {} local request_body = "" local res, code, response_headers, status = https.request{   url = "https://test:test@10.0.0.230/api/display/image?display=ext1",   method = "DELETE",   source = ltn12.source.string(request_body),   sink = ltn12.sink.table(response_body),   protocol = "tlsv1_2" }. if code == 200 then   log("Image deleted successfully!") else   log("Error deleting image: "..code) end else   log('ERROR') end
I found some threads here about digest authentication and image handling, but I'm not experienced with coding so I was not able to put the code together from what I found to do what I need.
I have saved the image to /img/ which i created in the root of the ftp server logged in as ftp.
Here's a link to the 2N API documentation, part 5.9.2 is about sending images and clearing the display.
https://wiki.2n.com/hip/hapi/latest/en
HTTP PUT image to 2N intercom - by coolaew - 07.02.2023, 23:57
RE: HTTP PUT image to 2N intercom - by admin - 08.02.2023, 11:21
RE: HTTP PUT image to 2N intercom - by admin - 09.02.2023, 07:58
