Python code to LUA
Hi there,
I'm looking to convert this python code to LUA.
I have no clue how to start.
Can this be done?
Any help would be greatly appreciated.
The full code is attached to this post.
These are the Classes :
# Copyright 2021, 2022 Milan Meulemans. # # This file is part of aioaseko. # # aioaseko is free software: you can redistribute it and/or modify # it under the terms of the GNU Lesser General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # aioaseko is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the # GNU Lesser General Public License for more details. # # You should have received a copy of the GNU Lesser General Public License # along with aioaseko.  If not, see <https://www.gnu.org/licenses/>. """aioAseko web API account.""" from __future__ import annotations from dataclasses import dataclass from aiohttp import ClientError, ClientResponse, ClientSession from .exceptions import APIUnavailable, InvalidAuthCredentials from .unit import Unit class WebAccount:     """Aseko web account."""     def __init__(self, session: ClientSession, username: str, password: str) -> None:         """Init Aseko account."""         self._session = session         self._username = username         self._password = password     async def _request(         self, method: str, path: str, data: dict | None = None     ) -> ClientResponse:         """Make a request to the Aseko web API."""         resp = await self._session.request(             method, f"https://pool.aseko.com/api/{path}", data=data         )         if resp.status == 401:             raise InvalidAuthCredentials         try:             resp.raise_for_status()         except ClientError:             raise APIUnavailable         return resp     async def login(self) -> AccountInfo:         """Login to the Aseko web API."""         resp = await self._request(             "post",             "login",             {                 "username": self._username,                 "password": self._password,                 "agree": "on",             },         )         data = await resp.json()         return AccountInfo(data["email"], data["userId"], data.get("language"))     async def get_units(self) -> list[Unit]:         """Get units."""         resp = await self._request("get", "units")         data = await resp.json()         return [             Unit(                 self,                 int(item["serialNumber"]),                 item["type"],                 item.get("name"),                 item.get("notes"),                 item["timezone"],                 item["isOnline"],                 item["dateLastData"],                 item["hasError"],             )             for item in data["items"]         ] @dataclass(frozen=True) class AccountInfo:     """Aseko account info."""     email: str     user_id: str     language: str | None
And this Is the code to run the classes :
from aiohttp import ClientSession from asyncio import run import aioaseko async def main():     async with ClientSession() as session:         account = aioaseko.MobileAccount(session, "aioAseko@example.com", "passw0rd")         try:             await account.login()         except aioaseko.InvalidAuthCredentials:             print("The username or password you entered is wrong.")             return         units = await account.get_units()         for unit in units:             print(unit.name)             await unit.get_state()             print(f"Water flow: {unit.water_flow}")             for variable in unit.variables:                 print(variable.name, variable.current_value, variable.unit)         await account.logout() run(main())
.gz   aioaseko-0.0.2.tar.gz (Size: 19.53 KB / Downloads: 2)
Python code to LUA - by bednarekluc - 16.02.2023, 17:16
RE: Python code to LUA - by Batko - 16.02.2023, 19:01
RE: Python code to LUA - by bednarekluc - 16.02.2023, 19:05
RE: Python code to LUA - by admin - 17.02.2023, 08:26
RE: Python code to LUA - by bednarekluc - 17.02.2023, 08:57
RE: Python code to LUA - by admin - 17.02.2023, 09:14
RE: Python code to LUA - by bednarekluc - 17.02.2023, 09:30
RE: Python code to LUA - by admin - 17.02.2023, 09:38
RE: Python code to LUA - by bednarekluc - 17.02.2023, 10:09
