27.02.2023, 11:29
Make sure that you have correct gateway and DNS settings in LM. Then check if you are using script for the correct CPU model that you have. After that install the system load app in LM and check that you have /usr/sbin/kamailio in the process list.
There's no UI of any kind, just the default configuration that allows SIP clients to call each other.
