Samsung / Tizen TV API v2
(27.02.2023, 13:40)admin Wrote: It seems that you need to send KEY_HOME first to get the access token. Then add this token to the query string for further calls: ...samsung.remote.control?name=NAME&token=TOKEN
Add another client:receive() after sending the key and log the results.
This is the script so far:
host = '192.168.126.54' port = 8001 name = 'SamsungTvRemote' b64 = require('encdec').base64enc ws = require('user.websocket') json = require('json') url = 'ws://' .. host .. ':' .. port .. '/api/v2/channels/samsung.remote.control?name=' .. b64(name) client, err = ws.client('sync', 10) res, err = client:connect(url) if not res then   log('connection failed', err)   return end data, _, _, opcode, err = client:receive() resp = json.pdecode(data) log(resp) if type(resp) ~= 'table' or resp.event ~= 'ms.channel.connect' then   log('invalid response', data, err)   client:close()   return end key = 'KEY_HOME' payload = json.encode({   method = 'ms.remote.control',   params = {     Cmd = 'Click',     DataOfCmd = key,     Option = 'false',     TypeOfRemote = 'SendRemoteKey'   } }) client:send(payload) data, _, _, opcode, err = client:receive() resp = json.pdecode(data) log(resp) client:close()
The result is this:
Samsung TV websocket 27.02.2023 15:54:54
* table:
["event"]
  * string: ms.channel.unauthorized
* arg: 1
  * string: invalid response
* arg: 2
  * string: {"event":"ms.channel.unauthorized"}
* arg: 3
  * nil
Samsung / Tizen TV API v2 - by Joep - 24.02.2023, 13:59
RE: Samsung / Tizen TV API v2 - by admin - 24.02.2023, 14:13
RE: Samsung / Tizen TV API v2 - by Joep - 24.02.2023, 14:45
RE: Samsung / Tizen TV API v2 - by admin - 27.02.2023, 06:58
RE: Samsung / Tizen TV API v2 - by Joep - 27.02.2023, 13:23
RE: Samsung / Tizen TV API v2 - by admin - 27.02.2023, 13:40
RE: Samsung / Tizen TV API v2 - by Joep - 27.02.2023, 14:57
RE: Samsung / Tizen TV API v2 - by admin - 27.02.2023, 14:58
RE: Samsung / Tizen TV API v2 - by Joep - 27.02.2023, 15:36
RE: Samsung / Tizen TV API v2 - by admin - 27.02.2023, 15:49
RE: Samsung / Tizen TV API v2 - by Joep - 27.02.2023, 16:06
RE: Samsung / Tizen TV API v2 - by Joep - 23.02.2024, 11:16
