universal MQTT / Timer / Localbus event loop
I am running this code to react to incoming MQTT messages.
During execution, I access storage using a semaphore, but after a while I get 'failed to create semaphore'.
require('sem') -- wait for 5 seconds max before executing callback res1, res2 = sem.runlocked('eventlock', 5, function(lockres)   -- lock acquired   if lockres then     storage.set('my_storage', '')     return true, 'ok'   -- failed to acquire lock   elseif lockres == nil then     return nil, 'failed to create semaphore'   else     return nil, 'failed to lock semaphore'   end end) log(res1, res2)
In the documentation for semaphore:close(), it is stated:
Quote:
semaphore:close()
Closes the semaphore. Not required, semaphore handles are closed automatically when script execution ends
Do I explicitely need to do it in the case of an eventloop? What can I do to prevent failure to create a semaphore?
RE: universal MQTT / Timer / Localbus event loop - by spyder - 22.03.2023, 20:18
