Hue Brightness feedback
#66
@ Erwin,
I've installed a few (13) new Hue lamps and i'm trying to discover their lampnumbers via the discover script. I get a return in the log, but not all lamps are there. Any idea?
Hue discovery 24.03.2023 08:18:54 * string: 192.168.100.187 Hue discovery 24.03.2023 08:18:54 * table: [1]   * string: [{"error":{"type":101,"address":"","description":"link button not pressed"}}] Hue discovery 24.03.2023 08:18:55 * table: [1]   * string: [{"success":{"/lights":"Searching for new devices"}}] Hue discovery 24.03.2023 08:18:55 string: { “1":{"state":{"on":false,"bri":254,"hue":41490,"sat":78,"effect":"none","xy":[0.3116,0.3277],"ct":153,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-12-03T14:06:43"},"type":"Extended color light”,"name":"Led terras”, "modelid":"LST004","manufacturername":"Signify Netherlands B.V.","productname":"Hue lightstrip outdoor”,"capabilities":{"certified":true,"control":{"mindimlevel":2000,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"huelightstrip","function":"mixed","direction":"omnidirectional","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:06:6a:54:98-0b","swversion":"1.101.2","swconfigid":"D771FA32","productid":"Philips-LST004-1-LedStripsOutv1"}, "3":{"state":{"on":false,"bri":254,"hue":41432,"sat":75,"effect":"none","xy":[0.3143,0.3302],"ct":156,"alert":"none","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-12-03T14:00:15"},"type":"Extended color light","name":"Keuken Werkblad R”, "modelid":"LCA001","manufacturername":"Signify Netherlands B.V.","productname":"Hue color lamp”,"capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:06:2e:13:af-0b","swversion":"1.101.2","swconfigid":"3C05E7B6","productid":"Philips-LCA001-5-A19ECLv6"}, "4":{"state":{"on":false,"bri":254,"hue":41432,"sat":75,"effect":"none","xy":[0.3143,0.3302],"ct":156,"alert":"none","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-12-03T14:00:25"},"type":"Extended color light","name":"Keuken Werkblad L”, "modelid":"LCA001","manufacturername":"Signify Netherlands B.V.","productname":"Hue color lamp”,"capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":800,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"sultanbulb","function":"mixed","direction":"omnidirectional","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:06:2c:ef:60-0b","swversion":"1.101.2","swconfigid":"3C05E7B6","productid":"Philips-LCA001-5-A19ECLv6"}, "5":{"state":{"on":false,"bri":254,"hue":8632,"sat":117,"effect":"none","xy":[0.4425,0.4060],"ct":343,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2023-02-16T16:21:36"},"type":"Extended color light","name":"Douche 1”, "modelid":"LCG002","manufacturername":"Signify Netherlands B.V.","productname":"Hue color spot”,"capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":300,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"spotbulb","function":"mixed","direction":"downwards","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:06:bb:4b:ae-0b","swversion":"1.101.10","swconfigid":"0982EB31","productid":"Philips-LCG002-1-GU10ECLv2"}, "6":{"state":{"on":false,"bri":254,"hue":8632,"sat":117,"effect":"none","xy":[0.4425,0.4060],"ct":343,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2023-02-16T16:27:01"},"type":"Extended color light","name":"Douche 2”, "modelid":"LCG002","manufacturername":"Signify Netherlands B.V.","productname":"Hue color spot”,"capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":300,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"spotbulb","function":"mixed","direction":"downwards","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:08:41:77:f1-0b","swversion":"1.101.10","swconfigid":"0982EB31","productid":"Philips-LCG002-1-GU10ECLv2"}, "7":{"state":{"on":false,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2021-12-12T13:50:30"},"type":"On/Off plug-in unit","name":"Hue Smart plug”, "modelid":"LOM002","manufacturername":"Signify Netherlands B.V.","productname":"Hue Smart plug”,"capabilities":{"certified":true,"control":{},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"plug","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:08:62:9c:b7-0b","swversion":"1.93.6","swconfigid":"7A0791B1","productid":"SmartPlug_OnOff_v01-00_02"}, "10":{"state":{"on":false,"bri":254,"hue":41432,"sat":75,"effect":"none","xy":[0.3143,0.3302],"ct":156,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-12-08T15:39:53"},"type":"Extended color light","name":"Keuken Wasbak”, "modelid":"929003116101","manufacturername":"Signify Netherlands B.V.","productname":"Perifo linear light bar”,"capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":1700,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"ceilinghorizontal","function":"mixed","direction":"downwards","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:0c:bd:de:f4-0b","swversion":"1.101.5","swconfigid":"83BB01E2","productid":"3241-3129-1221_HC07_PSG04"}, "11":{"state":{"on":false,"bri":254,"hue":41432,"sat":75,"effect":"none","xy":[0.3143,0.3302],"ct":156,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-12-08T14:16:02"},"type":"Extended color light","name":"Hanglamp Eiland 2”, "modelid":"929003115901","manufacturername":"Signify Netherlands B.V.","productname":"Perifo cylinder pendant”,"capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":510,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"pendantspot","function":"mixed","direction":"downwards","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:0d:1a:8b:aa-0b","swversion":"1.101.5","swconfigid":"85CF1793","productid":"4422-9556-4251_HC07_PSG04"}, "13":{"state":{"on":false,"bri":254,"hue":41432,"sat":75,"effect":"none","xy":[0.3143,0.3302],"ct":156,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2023-01-04T16:43:50"},"type":"Extended color light","name":"Hanglamp Eiland 1”, "modelid":"929003115901","manufacturername":"Signify Netherlands B.V.","productname":"Perifo cylinder pendant”,"capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":510,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.1700,0.7000],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"pendantspot","function":"mixed","direction":"downwards","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:0c:69:83:d8-0b","swversion":"1.101.5","swconfigid":"85CF1793","productid":"4422-9556-4251_HC07_PSG04"}, "14":{"state":{"on":false,"bri":254,"hue":39391,"sat":14,"effect":"none","xy":[0.3682,0.3715],"ct":230,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2023-03-24T07:16:31"},"type":"Extended color light","name":"Eetplaats Balk”, "modelid":"5060730P7_01","manufacturername":"Signify Netherlands B.V.","productname"...
As you can see there are ... but even that lamp is not complete.
user.lua: V5
Kind regards
Novice DIY with a HL and KNX basics trying to ...
Hue Brightness feedback - by Arjen Straver - 05.07.2017, 19:30
RE: Hue Brightness feedback - by Hippolyte - 19.07.2017, 15:14
RE: Hue Brightness feedback - by Hippolyte - 27.07.2017, 07:03
RE: Hue Brightness feedback - by Albertor - 21.11.2017, 18:22
RE: Hue Brightness feedback - by Albertor - 22.11.2017, 19:51
RE: Hue Brightness feedback - by DarthPaul - 13.08.2018, 12:19
RE: Hue Brightness feedback - by DarthPaul - 14.08.2018, 04:42
RE: Hue Brightness feedback - by admin - 13.08.2018, 12:40
RE: Hue Brightness feedback - by ralwet - 19.10.2018, 20:28
RE: Hue Brightness feedback - by FatMax - 30.11.2018, 16:36
RE: Hue Brightness feedback - by admin - 30.11.2018, 16:48
RE: Hue Brightness feedback - by FatMax - 01.12.2018, 02:58
RE: Hue Brightness feedback - by admin - 03.12.2018, 07:49
RE: Hue Brightness feedback - by FatMax - 03.12.2018, 07:59
RE: Hue Brightness feedback - by timchan054 - 02.01.2019, 01:13
RE: Hue Brightness feedback - by Daniel - 02.01.2019, 13:05
RE: Hue Brightness feedback - by lenze90 - 24.02.2019, 10:07
RE: Hue Brightness feedback - by Daniel - 25.02.2019, 09:13
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 09:02
RE: Hue Brightness feedback - by admin - 21.08.2019, 09:22
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 10:20
RE: Hue Brightness feedback - by Tee_Trinker - 08.05.2020, 22:31
RE: Hue Brightness feedback - by Tee_Trinker - 13.05.2020, 19:47
RE: Hue Brightness feedback - by Firechief - 08.06.2020, 16:16
RE: Hue Brightness feedback - by Firechief - 09.06.2020, 08:24
RE: Hue Brightness feedback - by Ravi Kiran S - 25.03.2021, 10:51
RE: Hue Brightness feedback - by MLa - 30.07.2020, 20:03
RE: Hue Brightness feedback - by MLa - 31.07.2020, 18:05
RE: Hue Brightness feedback - by Sral1987 - 02.08.2020, 17:25
RE: Hue Brightness feedback - by Sral1987 - 09.08.2020, 08:27
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 15:48
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 16:03
RE: Hue Brightness feedback - by Sral1987 - 01.05.2023, 08:44
RE: Hue Brightness feedback - by Firechief - 08.11.2020, 12:35
RE: Hue Brightness feedback - by admin - 09.11.2020, 08:23
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 15:17
RE: Hue Brightness feedback - by admin - 09.11.2020, 15:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 16:24
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:13
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 17:31
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 18:15
RE: Hue Brightness feedback - by Sral1987 - 27.11.2020, 17:36
RE: Hue Brightness feedback - by admin - 30.11.2020, 07:26
RE: Hue Brightness feedback - by Sral1987 - 30.11.2020, 15:59
RE: Hue Brightness feedback - by Sral1987 - 01.12.2020, 15:21
RE: Hue Brightness feedback - by Karaffe - 21.01.2022, 07:50
RE: Hue Brightness feedback - by Firechief - 25.03.2023, 14:56
RE: Hue Brightness feedback - by admin - 27.03.2023, 05:28
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 07:47
RE: Hue Brightness feedback - by admin - 28.03.2023, 07:58
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:31
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:31
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:35
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:39
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:41
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 11:32
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 13:38
RE: Hue Brightness feedback - by NKereshki - 24.04.2023, 06:33
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 11:31
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:06
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:27
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:38
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:42
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:45
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 14:16
RE: Hue Brightness feedback - by Daniel - 23.07.2025, 14:25
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 08:26
RE: Hue Brightness feedback - by admin - 24.07.2025, 08:39
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 09:14
RE: Hue Brightness feedback - by admin - 24.07.2025, 09:22
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 12:40
RE: Hue Brightness feedback - by admin - 24.07.2025, 12:54
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 14:29
RE: Hue Brightness feedback - by Sral1987 - 28.07.2025, 05:45
RE: Hue Brightness feedback - by NKereshki - 28.07.2025, 11:18
RE: Hue Brightness feedback - by admin - 25.07.2025, 07:06
RE: Hue Brightness feedback - by NKereshki - 30.07.2025, 19:27
RE: Hue Brightness feedback - by stianj - 31.07.2025, 09:40
RE: Hue Brightness feedback - by Daniel - 31.07.2025, 07:37
RE: Hue Brightness feedback - by Sral1987 - 01.08.2025, 04:53
