Processing KNX Addresses
Hello to all,
I'm new to the forum and lua scripting. I read some examples but didn't find anything suitable for my case.
I need to check multiple KNX addresses to determine a state change from 0 to 1. Specifically, I have the following logic: group/function/device. The number of devices varies for each group, but always starts at 11 and increases by 10.
If the state of address 1/2/11 or any of the addresses 1/2/X becomes 1, I need to change the state of all devices of type 1/3/Y and 1/5/Z. For example, if the address 1/2/11 is 1, then the addresses 1/3/11, 1/3/21, 1/3/31...(up to the number of objects entered) will change to 0, and the addresses 1/5/18, 1/5/28, 1/5/38...(up to the number of objects entered) will also change to 0. In other words, if any device from group 1 and function 2 has a state of 1, then all devices with functions 3 and 5 will change to a state of 0. If all devices from group 1 with function 2 have a state of 0 and control is allowed (the control address is X/2/0 for each group), then all devices with functions 3 and 5 will change to a state of 1.
What is the best practice for implementing this logic? I assume a resident script with a sleep of 0 is necessary, but with tags or first checking if the addresses exist, then using a for loop. Which solution will be most efficient and reliable for operation?
It is important to note that the groups range from 1 to 60, and the devices range from 11 to 161, always increasing by 10.
Processing KNX Addresses - by AISystem - 10.05.2023, 07:13
RE: Processing KNX Addresses - by admin - 10.05.2023, 07:30
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 08:24
RE: Processing KNX Addresses - by admin - 10.05.2023, 08:49
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 11:50
RE: Processing KNX Addresses - by admin - 10.05.2023, 11:51
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 12:05
RE: Processing KNX Addresses - by admin - 10.05.2023, 12:33
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 14:21
RE: Processing KNX Addresses - by admin - 11.05.2023, 05:59
RE: Processing KNX Addresses - by AISystem - 11.05.2023, 07:28
RE: Processing KNX Addresses - by admin - 11.05.2023, 12:18
RE: Processing KNX Addresses - by AISystem - 22.05.2023, 11:29
RE: Processing KNX Addresses - by admin - 22.05.2023, 12:01
RE: Processing KNX Addresses - by AISystem - 25.05.2023, 07:14
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 08:55
RE: Processing KNX Addresses - by admin - 29.05.2023, 09:41
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 10:33
RE: Processing KNX Addresses - by admin - 29.05.2023, 10:58
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 11:23
RE: Processing KNX Addresses - by admin - 29.05.2023, 11:48
