Processing KNX Addresses
This would lead to the possibility of many errors, can't it be done with a resident script that monitors states and processes events? I tried to write something similar, but apparently I don't understand the system's workings very well and it doesn't work for me.
local function object_exists(obj_address)   local obj = grp.find(obj_address)   return obj ~= nil end -- table with the addresses of function_one local function_one = {} for i = 1, 60 do   for j = 11, 241, 10 do     local function_one_address = i .. "/2/" .. j     if object_exists(function_one_address) then       function_one[(i - 1) * 24 + (j - 11) / 10 + 1] = function_one_address     end   end end -- table with the addresses of group_numbers local group_numbers = {} for i = 1, 60 do   for j = 11, 241, 10 do     local group_numbers_address = i .. "/3/" .. j     if object_exists(group_numbers_address) then       group_numbers[(i - 1) * 24 + (j - 11) / 10 + 1] = group_numbers_address     end   end end -- create client client = require('localbus').new(0.1) local function update_group_numbers_for_group(group_number)   local has_true_function_one = false   for j, function_one_item in ipairs(function_one) do     if tonumber(function_one_item:match("(%d+)/2/%d+")) == group_number then       if grp.getvalue(function_one_item) == 1 then         has_true_function_one = true         break       end     end   end   for j, group_number_item in ipairs(group_numbers) do     if tonumber(group_number_item:match("(%d+)/3/%d+")) == group_number then       local current_group_number_state = grp.getvalue(group_number_item)       if has_true_function_one and current_group_number_state == 1 then         grp.write(group_number_item, 0)       elseif not has_true_function_one and current_group_number_state == 0 then         grp.write(group_number_item, 1)       end     end   end end -- set function to handle events from group addresses client:sethandler('groupwrite', function(event)   local address = event.dst   local value = tonumber(event.datahex, 16) or 0   -- check if the address is in the list of function_one addresses   for i, function_one_item in ipairs(function_one) do     if address == function_one_item then       local group_number = tonumber(function_one_item:match("(%d+)/2/%d+"))       update_group_numbers_for_group(group_number)       break     end   end end) -- start the client for data exchange on the local bus client:loop(1)
Processing KNX Addresses - by AISystem - 10.05.2023, 07:13
RE: Processing KNX Addresses - by admin - 10.05.2023, 07:30
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 08:24
RE: Processing KNX Addresses - by admin - 10.05.2023, 08:49
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 11:50
RE: Processing KNX Addresses - by admin - 10.05.2023, 11:51
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 12:05
RE: Processing KNX Addresses - by admin - 10.05.2023, 12:33
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 14:21
RE: Processing KNX Addresses - by admin - 11.05.2023, 05:59
RE: Processing KNX Addresses - by AISystem - 11.05.2023, 07:28
RE: Processing KNX Addresses - by admin - 11.05.2023, 12:18
RE: Processing KNX Addresses - by AISystem - 22.05.2023, 11:29
RE: Processing KNX Addresses - by admin - 22.05.2023, 12:01
RE: Processing KNX Addresses - by AISystem - 25.05.2023, 07:14
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 08:55
RE: Processing KNX Addresses - by admin - 29.05.2023, 09:41
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 10:33
RE: Processing KNX Addresses - by admin - 29.05.2023, 10:58
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 11:23
RE: Processing KNX Addresses - by admin - 29.05.2023, 11:48
