Processing KNX Addresses
Use this as a starting point and fill in the blanks Smile
1. inputgroup maps group address to group id. groupobjects contains group address to value map for each group id. If object is not found then it won't be added.
local inputgroup = {} local groupobjects = {} for i = 1, 60 do   groupobjects[ i ] = {}   for j = 11, 241, 10 do     local addr = i .. "/2/" .. j     local value = grp.getvalue(addr)     if value ~= nil then       inputgroup[ addr ] = i       groupobjects[ i ][ addr ] = value     end   end end
2. In groupwrite handler check if destination group address belongs to a certain group id. If so then new value is cached and updategroup is called.
local addr = event.dst local group = inputgroup[ addr ] if group then   local value = tonumber(event.datahex, 16) ~= 0   groupobjects[ group ][ addr ] = value   updategroup(group) end
3. updategroup checks if there's at least one group address in the group that is on (true). Place this function before the groupwrite handler.
local function updategroup(group)   local objects = groupobjects[ group ]   local groupon = false   for addr, value in pairs(objects) do     if value then       groupon = true       break     end   end   log(groupon) end
For outputs you can simply use grp.checkwrite to prevent sending the same values.
Processing KNX Addresses - by AISystem - 10.05.2023, 07:13
RE: Processing KNX Addresses - by admin - 10.05.2023, 07:30
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 08:24
RE: Processing KNX Addresses - by admin - 10.05.2023, 08:49
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 11:50
RE: Processing KNX Addresses - by admin - 10.05.2023, 11:51
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 12:05
RE: Processing KNX Addresses - by admin - 10.05.2023, 12:33
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 14:21
RE: Processing KNX Addresses - by admin - 11.05.2023, 05:59
RE: Processing KNX Addresses - by AISystem - 11.05.2023, 07:28
RE: Processing KNX Addresses - by admin - 11.05.2023, 12:18
RE: Processing KNX Addresses - by AISystem - 22.05.2023, 11:29
RE: Processing KNX Addresses - by admin - 22.05.2023, 12:01
RE: Processing KNX Addresses - by AISystem - 25.05.2023, 07:14
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 08:55
RE: Processing KNX Addresses - by admin - 29.05.2023, 09:41
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 10:33
RE: Processing KNX Addresses - by admin - 29.05.2023, 10:58
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 11:23
RE: Processing KNX Addresses - by admin - 29.05.2023, 11:48
