Processing KNX Addresses
I generally don't understand something. I tried using the advice you gave me, but apparently I'm not using them correctly.
local inputgroup = {} local groupobjects = {} for i = 1, 60 do   groupobjects[i] = {}   for j = 11, 241, 10 do     local addr = i .. "/2/" .. j     local status, value = pcall(grp.getvalue, addr)     if status and value ~= nil then       inputgroup[addr] = i       groupobjects[i][addr] = value     end   end end local function updategroup(group)   local objects = groupobjects[group]   local groupon = false   for addr, value in pairs(objects) do     if value then       groupon = true       break     end   end   log(groupon)   local controlAddress = group .. '/2/0'   local isControlEnabled = grp.getvalue(controlAddress)   if isControlEnabled and isControlEnabled ~= nil then     local changeState = not groupon     for i = 11, 161, 10 do       local address3 = group .. '/3/' .. i       local address5 = group .. '/5/' .. (i + 7)       if pcall(grp.getvalue, address3) then         grp.checkwrite(address3, changeState)       end       if pcall(grp.getvalue, address5) then         grp.checkwrite(address5, changeState)       end     end   end end local function onStateChange(event)   local addr = event.dst   local group = inputgroup[addr]   if group then     local value = tonumber(event.datahex, 16) ~= 0     groupobjects[group][addr] = value     updategroup(group)   end end client = require('localbus').new(0.1) if event then   for group = 1, 60 do     for device = 11, 161, 10 do       local address = group .. '/2/' .. device       if pcall(grp.getvalue, address) then         event.register(address, onStateChange, 'groupwrite')       end     end   end else   log('event not available') end while true do   client:loop(1) end
Processing KNX Addresses - by AISystem - 10.05.2023, 07:13
RE: Processing KNX Addresses - by admin - 10.05.2023, 07:30
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 08:24
RE: Processing KNX Addresses - by admin - 10.05.2023, 08:49
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 11:50
RE: Processing KNX Addresses - by admin - 10.05.2023, 11:51
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 12:05
RE: Processing KNX Addresses - by admin - 10.05.2023, 12:33
RE: Processing KNX Addresses - by AISystem - 10.05.2023, 14:21
RE: Processing KNX Addresses - by admin - 11.05.2023, 05:59
RE: Processing KNX Addresses - by AISystem - 11.05.2023, 07:28
RE: Processing KNX Addresses - by admin - 11.05.2023, 12:18
RE: Processing KNX Addresses - by AISystem - 22.05.2023, 11:29
RE: Processing KNX Addresses - by admin - 22.05.2023, 12:01
RE: Processing KNX Addresses - by AISystem - 25.05.2023, 07:14
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 08:55
RE: Processing KNX Addresses - by admin - 29.05.2023, 09:41
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 10:33
RE: Processing KNX Addresses - by admin - 29.05.2023, 10:58
RE: Processing KNX Addresses - by AISystem - 29.05.2023, 11:23
RE: Processing KNX Addresses - by admin - 29.05.2023, 11:48
