MqTT in Wiser for KNX
#23
This is done to prevent a possible loop when the same object is mapped to the same topic in both directions.
You can remove this check like this:
function publishvalue(event)     -- message from us or client is not connected     -- if event.sender == 'mq' or not mclientfd then     if not mclientfd then       return     end
MqTT in Wiser for KNX - by JRP - 20.05.2020, 12:11
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 12:40
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 13:55
RE: MqTT in Wiser for KNX - by Daniel - 20.05.2020, 13:59
RE: MqTT in Wiser for KNX - by JRP - 20.05.2020, 18:34
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 07:21
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 10:40
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 10:42
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:20
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:22
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 11:47
RE: MqTT in Wiser for KNX - by Daniel - 21.05.2020, 11:50
RE: MqTT in Wiser for KNX - by JRP - 21.05.2020, 15:28
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 10:38
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 11:06
RE: MqTT in Wiser for KNX - by admin - 26.08.2022, 12:55
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:18
RE: MqTT in Wiser for KNX - by admin - 19.05.2023, 10:24
RE: MqTT in Wiser for KNX - by JRP - 19.05.2023, 10:42
RE: MqTT in Wiser for KNX - by JRP - 20.05.2023, 17:10
RE: MqTT in Wiser for KNX - by admin - 22.05.2023, 06:52
RE: MqTT in Wiser for KNX - by JRP - 26.05.2023, 08:21
