LUA scripting using ChatGPT for the LogicMachine
Hi everyone,
just tried talking to ChatGPT to ask it to code me a script to get my external IP, store it locally and if there is a change to update my no-ip dyndns for me.
Check out this code it returned on the first try:
-- Import required libraries local http = require("socket.http") local ltn12 = require("ltn12") local mime = require("mime") local storage = require("storage") -- Define your No-IP account details local username = "your_noip_username" local password = "your_noip_password" local hostname = "your_noip_domain" -- Define the URL for retrieving the external IP address local ipUrl = "http://api.ipify.org/" -- Perform the request to retrieve the IP address local response = {} local result, status = http.request {   url = ipUrl,   method = "GET",   sink = ltn12.sink.table(response) } -- Check the response status if status == 200 then   local externalIP = table.concat(response)   log("External IP address: " .. externalIP)     -- Retrieve the stored IP address from LogicMachine storage   local storedIP = storage.get("externalip")     -- Compare the retrieved IP with the stored IP   if storedIP == externalIP then     log("No change in IP address. No update needed.")     return   end     -- Save the updated IP address to LogicMachine storage   storage.set("externalip", externalIP)   log("IP address updated and saved to LogicMachine storage.")     -- Continue with No-IP update code   -- Define the update URL with the retrieved IP address   local updateUrl = "http://dynupdate.no-ip.com/nic/update?hostname=" .. hostname .. "&myip=" .. externalIP     -- Define the authentication header   local auth = username .. ":" .. password   local authHeader = "Basic " .. (mime.b64(auth))   -- Define the request headers   local headers = {     ["Authorization"] = authHeader   }   -- Perform the update request   local updateResponse = {}   local updateResult, updateStatus = http.request {     url = updateUrl,     method = "GET",     headers = headers,     sink = ltn12.sink.table(updateResponse)   }   -- Check the update response status   if updateStatus == 200 then     local responseBody = table.concat(updateResponse)     log("Update successful. Response from No-IP: " .. responseBody)   else     log("Update failed. Status code: " .. updateStatus)   end else   log("Failed to retrieve the external IP address. Status code: " .. status) end
the only change necessary was removing the
line and it runs in a resident scrip without fail!
LUA scripting using ChatGPT for the LogicMachine - by managementboy - 22.05.2023, 10:38
