VPN ISSUES ON PORT 3671
I have problems with n°2 LM installed on the same LAN.
The currently installed firmware version is the 20230420.
The two lLM can be reached in LAN both on port tcp 80 and on udp 3671 for connection in ETS.
the problem arises with the VPN connection: port 3671 is no longer reachable, port 80 still reachable.
the customer's network manager assures me that there is no restriction and it should be possible to connect: in fact, on the same network there is a KNX IP-ROUTER that uses the same port and does not present difficulties in connecting.
What could be the cause of this problem, present on both LMs?
Also, I wanted to point out that often the connection in Zerotier is unstable. Maybe since we updated the signature.
Thank you for your support
Peppe
VPN ISSUES ON PORT 3671 - by gdimaria - 08.06.2023, 16:12
RE: VPN ISSUES ON PORT 3671 - by Daniel - 08.06.2023, 16:14
RE: VPN ISSUES ON PORT 3671 - by gdimaria - 08.06.2023, 18:29
RE: VPN ISSUES ON PORT 3671 - by admin - 09.06.2023, 07:04
RE: VPN ISSUES ON PORT 3671 - by gdimaria - 09.06.2023, 13:16
RE: VPN ISSUES ON PORT 3671 - by Geert - 18.08.2023, 12:43
RE: VPN ISSUES ON PORT 3671 - by admin - 18.08.2023, 12:44
RE: VPN ISSUES ON PORT 3671 - by Geert - 21.08.2023, 08:11
RE: VPN ISSUES ON PORT 3671 - by rocfusion - 25.08.2023, 00:40
