20.01.2017, 08:18
(This post was last modified: 20.01.2017, 08:21 by Erwin van der Zwart.)
There is a memory leak found in FW 1.2.0 and you have to upgrade to FW 1.2.1 to fix this problem.
When memory is 85% the upgrade might fail. Try to stop most scripts, reboot and perform upgrade direct while memory is still low.
You can find FW 1.2.1 by using the about tab in the spaceLYnk.
This would solve your memory problem.
Don't forgot to make back-up first to be sure (:
