JSON decode
(18.07.2023, 16:10)Dré Wrote: Hi Joep,
Will you share how you did the rest done, like request the for the right postcode/place?
Hi Dré,
First you need to check if this API is available for your address. See if you get info when adding your zipcode and house number to this url https://mijnafvalwijzer.nl/
If it works you can use the script below:
require('socket.http') json = require('json') socket.http.TIMEOUT = 5 data = socket.http.request('https://api.mijnafvalwijzer.nl/webservices/appsinput/?apikey=YOUR-API-KEY-HERE&method=postcodecheck&postcode=YOUR_ZIPCODE_HERE&street=&huisnummer=YOUR-HOUSE-NUMBER-HERE&toevoeging=&app_name=afvalwijzer&platform=phone&afvaldata=' .. os.date("%Y") .. '-01-01&langs=nl') data = json.pdecode(data) for key, value in pairs(data.ophaaldagen.data) do   if value.date == os.date("%Y-%m-%d") then     if value.nameType == "restafval" then       log("grijze kliko")     elseif value.nameType == "gft" then       log("groene kliko")     elseif value.nameType == "plastic" then       log("plastic afval")     end   end end
JSON decode - by Joep - 05.07.2023, 15:28
RE: JSON decode - by Erwin van der Zwart - 06.07.2023, 06:15
RE: JSON decode - by Joep - 06.07.2023, 13:51
RE: JSON decode - by Dré - 18.07.2023, 16:10
RE: JSON decode - by Joep - 19.07.2023, 12:58
