13.09.2023, 13:16
(13.09.2023, 07:44)admin Wrote: This logic part is wrong: 19 <= hour and hour <= 7
Another issue with this script is that if the input object value is false it will first write 70 then 0 to the output. This can cause the light to flicker.
Corrected version (event script, as it should be):
Code:value = event.getvalue() if value then hour = os.date('*t').hour if hour <= 7 or hour >= 19 then out = 10 else out = 70 end else out = 0 end grp.checkwrite('1/4/30', out)
Tnx, is it also possible to add multiple time frames by just copying them and changing the timr?
