the average value of tagged objects
HI,
I've tried this script also for obtaining an average value of some temperature values obtained from a temperature sensor that send values at 5-10 second.
The script should work at each 10 min(scheduled script), and calculate the average value for the elapsed time from the last run
Maybe something I make wrong, or I just miss something.
13/2/9 - is the GA where the sensor sends the values
13/2/11 - should be the average value of received value.
This is script:
if not client then  -- each group has 3 fields:  -- tag - status object tag  -- output - status output object  -- mode - calculate mode (and/or/avg)  groups = {      { tag = '13/2/9', output = '13/2/11', mode = 'avg' },  }  -- time to wait between last telegram from any status in group and update  updatedelay = 0.5  -- object value cache  values = {}  -- object datatype cache  datatypes = {}  -- send update only when value changes  grp.checkupdate = function(alias, value)    if values[ alias ] ~= value then      grp.update(alias, value)    end  end  calc = {}  -- AVERAGE value  calc['avg'] = function(group)    local result, count, value = 0, 0    for _, address in ipairs(group.objects) do      value = values[ address ]      -- number must be in [0..100] range      if type(value) == 'number' then        result = result + value        count = count + 1      -- boolean true is 100%, false is 0%      elseif type(value) == 'boolean' then        if toboolean(value) then          result = result + 100        end        count = count + 1      end    end    if count > 0 then      result = math.floor(result / count + 0.5)      grp.checkupdate(group.output, result)    end  end  -- AND gate  calc['and'] = function(group)    local result = true    for _, address in ipairs(group.objects) do      result = result and toboolean(values[ address ])    end    grp.checkupdate(group.output, result)  end  -- OR gate  calc['or'] = function(group)    local result = false    for _, address in ipairs(group.objects) do      result = result or toboolean(values[ address ])    end    grp.checkupdate(group.output, result)  end  -- prepare each group  for _, group in ipairs(groups) do    object = grp.find(group.output)    -- cache output status object value and datatype    values[ object.address ] = object.data    datatypes[ object.address ] = object.datatype    group.output = object.address    -- group input status object list    group.objects = {}    -- find all status objects and cache values and datatypes    objects = grp.tag(group.tag)    for _, object in ipairs(objects) do      values[ object.address ] = object.data      datatypes[ object.address ] = object.datatype      table.insert(group.objects, object.address)    end    -- force update on first run    group.timer = 0    -- calc function reference    group.fn = calc[ group.mode ]  end  -- handle group writes  function eventhandler(event)    local dst, datatype    dst = event.dst    datatype = datatypes[ event.dst ]    -- unknown object, stop    if not datatype then      return    end    values[ dst ] = dpt.decode(event.datahex, datatype)    -- check if any group needs to be updated    for _, group in ipairs(groups) do      for _, address in ipairs(group.objects) do        if address == dst then          group.timer = updatedelay        end      end    end  end  require('genohm-scada.eibdgm')  client = eibdgm:new({ timeout = 0.25 })  client:sethandler('groupwrite', eventhandler) end tsec, tusec = os.microtime() client:step() delta = os.udifftime(tsec, tusec) -- check if any group has an active timer for _, group in ipairs(groups) do  timer = group.timer  if timer then    timer = timer - delta    -- timer expired, run calc function    if timer <= 0 then      group.fn(group)      timer = nil    end    group.timer = timer  end end
RE: the average value of tagged objects - by sorin - 30.01.2017, 13:47
