the average value of tagged objects
No, this script cannot be used to calculate averages for a single group address because it does not store any historical info.
Since your sensor sends data periodically, you can map an event script to 13/2/9 which will store values and calculate average once 10 minutes pass.
-- storage key key = 'temp_average' -- time between average value send (in seconds) maxtime = 10 * 60 -- resulting average value result = '13/2/11' time = os.time() data = storage.get(key) if not data then   data = { values = {}, time = time } end value = event.getvalue() table.insert(data.values, value) delta = time - data.time if delta >= maxtime or delta < 0 then   storage.delete(key)   avg = 0   count = #data.values   for _, value in ipairs(data.values) do     avg = avg + value   end   grp.write(result, avg / count) else   storage.set(key, data) end
RE: the average value of tagged objects - by admin - 31.01.2017, 07:48
