Run tunable white (HCL)
(21.09.2023, 12:48)admin Wrote: The script does not use color temperature in K but simply 0..100% scale from warmest to coldest. It's up to you which approach to use.
If LED parameters are known you can tune the formula to get a more consistent brightness across the whole color temperature range.
ok i made a first try with scripting but i am not sure if it is right :-)
--Tunable White br = event.getvalue('1/5/10') ct = event.getvalue('1/0/14') br = 100 -- brightness (0..100%) ct = 50 -- color temperature (0..100%; 0 = warmest, 100 = coldest) ww = (100 - ct) * br / 100 -- warm white value (0..100%) cw = ct * br / 100 -- cold white value (0..100%) value = cw grp.write('32/6/1', value) value = ww grp.write('32/6/2', value) end
Run tunable white (HCL) - by FatMax - 11.08.2018, 14:21
RE: Run tunable white (HCL) - by admin - 12.08.2018, 10:15
RE: Run tunable white (HCL) - by admin - 13.08.2018, 11:24
RE: Run tunable white (HCL) - by tomnord - 09.10.2019, 19:40
RE: Run tunable white (HCL) - by FatMax - 14.08.2018, 09:44
RE: Run tunable white (HCL) - by admin - 10.10.2019, 07:03
RE: Run tunable white (HCL) - by tomnordstrom - 10.10.2019, 07:48
RE: Run tunable white (HCL) - by admin - 10.10.2019, 08:14
RE: Run tunable white (HCL) - by KoBra - 20.09.2023, 19:35
RE: Run tunable white (HCL) - by admin - 21.09.2023, 05:15
RE: Run tunable white (HCL) - by KoBra - 21.09.2023, 05:59
RE: Run tunable white (HCL) - by admin - 21.09.2023, 08:22
RE: Run tunable white (HCL) - by KoBra - 21.09.2023, 12:42
RE: Run tunable white (HCL) - by admin - 21.09.2023, 12:48
RE: Run tunable white (HCL) - by KoBra - 21.09.2023, 14:18
RE: Run tunable white (HCL) - by admin - 21.09.2023, 14:45
RE: Run tunable white (HCL) - by KoBra - 21.09.2023, 15:08
